Yes, the diode was failed. U'm not sure, that 1N4148 is a good choice for this job. It's too weak probably. I've replaced it with 1N4003. Problem was solved. I'ev added some additional code to check the situation with failed events in the scripts.
A project log for A-Hen-Ho
Automation of the hen house. Light, door, temperature tracking. Using Raspberry PI as main unit and Wi-Fi as connection-configuration link.
