After a successful routing, the boards have been sent off to OSH Park and will hopefully be back in time for the deadline... fingers crossed!
Program your AVR over WiFi using the standard ISP header already on your board!
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
This sounds pretty cool but I don't quite understand how the ISP protocol is implemented since the ESP-Link project only mentions programming AVRs with a serial bootloader.
Btw: In the schematics it looks like GPIO14/SCK is connected to Reset/GPIO16 which isn't the case, is it?
Thanks for the reply, writing your own module clarifies things a lot. From the description it sounded like it should work right out of the box with ESP-Link. It'd be great if you could make your firmware work with ESP-01 modules as well, using RX & TX as GPIO.
I should have guessed it was one of those late night schematics ;)
Hmmmmmm, it could work with the ESP01s, they do have the right number of pins :) I'll port it over when I get this contest 'squared' away :P
I think this might be helpful to people wanting to use this programmer (or ESP-Link in general) with software other than Avrdude: https://hackaday.io/page/1304-virtual-serial-port-tunnel-to-use-with-esp-link
Just a friendly reminder to please upload your design documents by 23:59 UTC on Dec 8, 2015 to be in the running for #The Square Inch Project!
