Today is display day ;-)
I received these :
They are going to help a lot for the early design of the system. I started playing with them and I was not disappointed:
I'm concerned however about the power consumption. The datasheet is clear that this is not a low-power device.
Displaying "0" draws 0.5W!
Touching the package, I feel it's pretty warm. To me, a warm circuit is not a good circuit but that's the price of vintage here.
Fortunately, undervolting works. The display is "more or less stable" at 3.3V but for safety, 3.5V is a good compromise.
That's about 0.2W, which is "OK". A 4-digit display (16 bits) will draw about or less than 1 Watt, depending on the value.
But where do I find 3.5V switching regulators ? How do I modify one (like a cheap fixed-voltage device) to "offset" the voltage by 0.2V ? Any idea ?
There is also the parallel method of "blanking", but I'm not sure it also reduces the drain of the decoding logic.
You can get 3.5Volts by means of a MC34063 or another DC-DC converter.
I'm lazy so I reused a TI sample of PTV05010W
I know, overkill. But it's easy and tiny, ready made and no need of large caps :-)
Whoa! 8A!! But you're right, the thing is ready and your objective is not a PSU but a retro 16 bit computer.
It's not retro, it's steampunk ;-)
and the "oversized" module has two benefits : I just put 2 large ceramic caps on input and output, no need of extra decoupling since I won't reach 8A, and I can power most of the TIL311 of the system with 1 regulator (that can be turned off).
And I chose it for the very compact size too :-)
I would have spent more time and PCB surface with a MC34063 or LM2575 and my time is getting short...
Heh, looking at that image I first thought you had ordered tons of red boards and forgot to upload your soldermask gerber :P
Hahahaha :-)
Same for me! I have 6 of them lying around waiting for the day they'll become a clock.
What are you waiting for ? others have done it and it's quite easy with these parts :-)
Good luck !
I have some stuff to finish first. But either way thank you for the incentive! At lease at took them from the drawer to take a look. I was wrong about the amount of pieces. I have 6 units of HP5082-7300 and 3 units of TIL311 (from Texas).
Whoa, you got a lot of 'em! I've four in my supply, I keep 'em round like gold, they're so easy to throw on a bus. Good luck with the power-consumption issue!
They should not be thrown /under/ a bus though ;-)
