After Progress, at last !, I went looking for "ribs" (or "fishbones") or the backbone of the system.
I found extra-long pins on eBay in sufficient quantities, smaller than what I have in stock but still enough to stack 5 pages. It should be enough for the first implementations...
I received samples from Würth Elektronik !
Thanks to the cool rep, we found a reference that is longer than the previous ones, almost 40mm (so the above picture is a reminder for the reference for a next order)
I might have also found very interesting prototype boards that can be slightly bent...
Yann Guidon / YGDES
