The more I explore hacking, the more I get into retro computing and I am increasingly fascinated by Unix and Unix-like systems. Taking some inspiration from this N-O-D-E project (http://tinyurl.com/ovmo3ux), I decided to make a pocket sized GNU/Linux terminal, with the intention of honing in my command line skills. There will be some differences between mine and the N-O-D-E project, namely the use of a RPi B+ instead of an A+ for better resources, and a bigger screen for better viewing. Some other small changes will be documented that will further differentiate this project, as well.
