Photo for demonstration that it works
12/23/2015 at 14:25 • 0 commentsYesterday I've uploaded a photo to demonstrate that the product works (as required by the Square Inch Project.) Temperature readings are in celcius. The lower resolution readings are from the TC74 and the higher resolution (and more accurate) readings are from the DS1631. I used an MSP430G2 launchpad to get the readings from my board.
Wishing everyone a Merry Christmas!
Taking suggestions
11/25/2015 at 23:32 • 0 commentsThe project is mostly finished but I'm most certainly willing to take suggestions. I have been thinking about going from thru-hole to SMD resistors which help reduce board space. I've never worked with SMD resistors although I'd imagine it shouldn't be too difficult.
