Hackaday.io Hackaday.io
Sign up Log in
go:toTrash
A radio-controlled trashcan for an event against littering on the streets.
tim-gremalmTim Gremalm
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.1k views
2 comments
789 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 2
View Gallery
1.1k
2
789
4
Team (1)
  • tim-gremalmTim Gremalm
Join this project's team
  • http://tim.gremalm.se/?tag=gototrash
rc ROBOT servo Gothenburg Göteborg go:toTrash Radio-controlled Trashcan BLDC VOICE-Effects BLDC-Servo
Related lists
Raspberry Pi Projects
Projects based on everyone's favorite low cost Linux Machine - The Raspberry Pi
This project was created on 04/15/2014 and last updated 6 years ago.
Description
A radio-controlled trashcan for an event against littering on the streets. It's driven by 2 BLDC-servos and have an integrated speaker driven by ab RPi running mumble VoIP-server, Voice-effects by Jack Rack.
Components
  • 2 × Simplex Motion 100A BLDC servo 100W (400W peak) [http://simplexmotion.com/products/standard-products/]
  • 2 × Planetary gearbox 25:1 [http://www.oemmotor.se/Produkter/Vaxlar/Planetvaxlar/40mm_planetvaxel/501827-500433.html]
  • 1 × Raspberry Pi Model B Hosting a Mumble-server
Project Logs
Collapse
  • The making of go:toTrash
    Tim Gremalm • 10/26/2015 at 00:17 • 0 comments
    This is the making of go:toTrash were we are showing the steps involved in the construction.
View project log
Log In/Sign up to comment
Sign up with Github
OR
Eric Evenchick wrote 04/17/2014 at 21:57 • point
Nifty design idea. Do you chase litterers down with it and guilt them over VoIP?
Tim Gremalm wrote 04/23/2014 at 00:19 • point
Hehe, yeah, that's the idea!
Our approach is: "If people don't bother to move 2 meters to the nearest trashcan, the trashcan have to move to them."
I recently tested some popular microwave amateur radio software and found surprisingly bad results. I dug in and found some basic problems.
Project Owner Contributor
AREDN Under Test
martinMartin
Wireless Audio System using precise UWB indoor localization to provide : follow me and multi-room to users.
BSP Sound System
lahordeLahorde
This mailbox coordinates with a Raspberry Pi based router to block push notifications network-wide until a phone is placed inside.
The Mailblocks: Physical Inbox for Virtual Alerts
guy-dupontGuy Dupont
Supplyframe DesignLab: 2022 Hackada…
Remote Radio Message Recording, Queueing, and Transmission (for Normal and Emergency Communications)
Project Boondock Echo
mark-j-hughesMark J Hughes
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "go:toTrash", please tell us the reason.
Send message
Remove Member
