關閉
R-2R DAC inspired by tiny7 by al1
一個 project log 因為 Me building projects from hackaday.io
This is where I build and talk about projects designed by the great people of this community.
davedarkodavedarko • 11/04/2015 at 09:51•8 Comments
Inspired by #tiny7 by @al1
Following @Elliot Williams on youtube I noticed his next "logic noise" HaDblog post will feature R-2R DACs and an hour later I had this idea for a little project, using a shift register with some 6.8kOhm resistors I have too many of. Since I really liked the Idea of using the accessible ISP header on arduinos to send data to the shift register like the #tiny7 by @al1 does, I had to put this on a protoboard. Expect some weird sounds to follow, because they are nowhere near to be accurate with 5% tolerance resistors. This just screams for a self checking arduino script that writes data out and checks the output with analog input.
討論
Elliot Williams 撰寫 11/13/2015 at 21:12 • point
That's awesome.  I'm sure that you'll find for audio (for instance) that it works well enough.
Great call to drive it with a shift reg.
Watch the 127-128 transition (the most significant bit).  That's where the worst glitching will show up.  If you trim that out, 5%ers can work just fine.
It's not like a R-2R DAC is rocket science, though.  They're hella forgiving and super fun.
  您確定嗎? 是 | 否
Eric Hertz 撰寫 11/05/2015 at 14:08 • point
I read somewhere they used this method to build sound-cards on parallel ports way back in the day... there were even products based on it.
  您確定嗎? 是 | 否
davedarko 撰寫 11/05/2015 at 11:09 • point
I now remember ... it all started with a voice changer on instructables that used an arduino with a wave shield and the DAC was controlled by SPI. Seems like 4bit on a port would be much faster then a software controlled shift register though.
  您確定嗎? 是 | 否
Jarrett 撰寫 11/04/2015 at 19:29 • point
I was investigating this a few months ago as a method of building a super cheap analog value, and I think the numbers I came up with were max 5-bit accuracy with 5% resistors.
For bonus points, can you design something with tri-state outputs like a 74hc595 shift register and use a single resistor on each output as a voltage divider, using highs, lows, and high-Zs to stack resistors in parallel?
It's much harder to conceptualise, and your resistor values will need to be cleverly chosen, but it might be a fun brain problem.  :)
  您確定嗎? 是 | 否
davedarko 撰寫 11/05/2015 at 11:14 • point
Sadly I have enough brain problems already and don't quite get what you mean ;)
Most of the time I'm too lazy to do the maths and just try it out, so I'll post some graphs soon. I also have a MCP41100 or two, that should be interesting as well.
  您確定嗎? 是 | 否
Jarrett 撰寫 11/05/2015 at 17:31 • point
http://imgur.com/wUbhKX5
Drew a couple possible equivalents. Using 5v, 0v, or high-impedance outputs on the shift register, you should be able to generate an arbitrary analog value.
  您確定嗎? 是 | 否
