For Halloween I needed my old Fog Machine to be Wireless. So I modded the manual controller to be controlled by an Arduino
First you need to identify the controller lines and solder 2 wires from the switch
I drilled a hole through the top of the controller and sent the 2 lines out from the opening
When all is done it should look somehting like this. The fog machine requires a little bit to warm up and thats why they have a momentary switch.
I did one myself with a NW.js React app and Arduino Ethernet shield: https://github.com/jim-blog/fog-machine
