2Step 2
Since we need to bring down the roomba battery (up to 15V) to 3.3V we can't use a linear regulator. I'm using a cheap buck regulator ("Mini360 DC-DC Buck Converter Step Down Module") from ebay, but has also successfully used a R78B3.3-1.0 from Recom.
If you use the variable ebay one, make sure to set it to 3.3V before connecting it to the ESP module.
Ebay item: http://www.ebay.com/itm/351195883183?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
4Step 4
TODO:
- More connections and pin header connector.
- Downloading/Configuring/Compiling/Flashing firmware
- Opening the roomba (ifixit link ?)
- Points on Roomba PCB to use
- Over the air updates
- github merge requests.
