1Creating a 32-Bit UEFI comaptible Live Boot Stick
I like to write code listing so that they can be easily copypastad. Please do so at own risk. Some values, links etc. may be out of date. Instead of executing the code listing, you can also follow the instruction from the Arch Wiki Article.
# parameters date=2018.03.01 iso=archlinux-$date-x86_64.iso stick=/dev/sdb point=/mnt/usb0 # download Arch Linux wget http://mirrors.evowise.com/archlinux/iso/$date/$iso label=$(isoinfo -i $iso -d | grep "Volume id" | grep -o "\w*$") # create bootia32.efi echo " insmod part_gpt insmod part_msdos insmod fat insmod efi_gop insmod efi_uga insmod video_bochs insmod video_cirrus insmod font if loadfont \"${prefix}/fonts/unicode.pf2\" ; then insmod gfxterm set gfxmode=\"1024x768x32;auto\" terminal_input console terminal_output gfxterm fi menuentry \"Arch Linux archiso x86_64\" { set gfxpayload=keep search --no-floppy --set=root --label $label linux /arch/boot/x86_64/vmlinuz archisobasedir=arch archisolabel=$label add_efi_memmap initrd /arch/boot/x86_64/archiso.img } menuentry \"UEFI Shell x86_64 v2\" { search --no-floppy --set=root --label $label chainloader /EFI/shellx64_v2.efi } menuentry \"UEFI Shell x86_64 v1\" { search --no-floppy --set=root --label $label chainloader /EFI/shellx64_v1.efi }" > /tmp/grub.cfg grub-mkstandalone \ -d /usr/lib/grub/i386-efi/ -O i386-efi\ --modules="part_gpt part_msdos"\ --fonts="unicode"\ --locales="uk"\ --themes=""\ -o "/tmp/bootia32.efi"\ "boot/grub/grub.cfg=/tmp/grub.cfg" -v # partition and format USB stick sudo fdisk /dev/sdb << EEOF g n t 1 w EEOF sudo partprobe sudo mkfs.vfat -F 32 -n $label "$stick"1 # copy everything to USB stick sudo mount "$stick"1 $point sudo bsdtar xf $iso \ --exclude=isolinux/ \ --exclude=EFI/archiso/ \ --exclude=arch/boot/syslinux/ \ -C $point sudo cp /tmp/bootia32.efi $point/EFI/boot/bootia32.efi sync sudo eject $stick
2Installing Arch Linux
During your normal Arch installation you usually come to the point where you install the bootloader. In most cases either GRUB or systemd-boot. We will install GRUB.
For the following commands I assume, you have arch-chroot ed into the installation.
I also assume that /boot will be your EFI System Partition.pacman -S efibootmgr grub grub-install \ --target=i386-efi \ --efi-directory=/boot \ --bootloader-id=Archlinux grub-mkconfig -o /boot/grub/grub.cfg
