Front Crossmember cut to fit Smart Car controller
JPEG Image -
1.33 MB -
12/30/2015 at 21:52
Preview
Stock transmission bell housing
JPEG Image -
2.45 MB -
12/30/2015 at 21:52
Preview
CAD (cardboard aided design) (I'll learn solid works soon)
JPEG Image -
1.88 MB -
12/30/2015 at 21:52
Preview
Cutting the transmission input shaft for prototyping purposes. I will make a custom shaft eventually.
JPEG Image -
1.86 MB -
12/30/2015 at 21:51
Preview
Sonett interior
JPEG Image -
1.37 MB -
12/30/2015 at 21:51
Preview
Thinking about a tilt-up bonnet for my Sonett
JPEG Image -
1.36 MB -
12/30/2015 at 21:51
Preview
Cutting out rust
JPEG Image -
1.21 MB -
12/30/2015 at 21:51
Preview
prototyping engine/transmission shaft adaption.
JPEG Image -
2.12 MB -
12/30/2015 at 21:50
Preview
Middle engine-bay crossmember cut to fit mystery screw in motor. I can't get that screw out, but I'm guessing it's a drain plug for the coolant.
JPEG Image -
1.75 MB -
12/30/2015 at 21:50
Preview
Stock instrument cluster. Since the speedometer and odometer are mechanical off of the transmission I can use the originals! I'll get new gauges for the others.
JPEG Image -
1.41 MB -
12/30/2015 at 21:49
Preview
Engine/transmission hanging in place. Bolted in my the transmission pin and hooked up to the T drivers. Basically ready to go!
JPEG Image -
2.28 MB -
12/30/2015 at 21:49
Preview
Body-work. The drivers side brake line goes through the engine bay wall. It was full of holes.
JPEG Image -
1.13 MB -
12/30/2015 at 21:49
Preview
17 spline female motor shaft.
JPEG Image -
2.03 MB -
12/30/2015 at 21:49
Preview
"This is a two-bay job." or... What we do when we don't have to share for the weekend.
JPEG Image -
1.99 MB -
12/30/2015 at 21:48
Preview
My sweet winter set up. W/ heat
JPEG Image -
6.38 MB -
12/30/2015 at 20:23
Preview
So, the bearings are shot...
JPEG Image -
2.26 MB -
12/30/2015 at 20:23
Preview
Bits of bearing guides on my magnetic transmission drain plug
JPEG Image -
2.10 MB -
12/30/2015 at 20:23
Preview
Damn, I think this car is so hot.
JPEG Image -
1.91 MB -
12/30/2015 at 20:23
Preview
Sketch of the motor shaft spline pattern.
JPEG Image -
2.55 MB -
12/30/2015 at 20:23
Preview
I need another transmission. This one is bad.
JPEG Image -
2.25 MB -
12/30/2015 at 20:23
Preview
Transmission input shaft in the motor output shaft. The tranny shaft doesn't have splines, this was just to mockup the adapter plate.
JPEG Image -
1.44 MB -
12/30/2015 at 20:21
Preview
Motor and transmission. Together at last!
JPEG Image -
2.50 MB -
12/30/2015 at 20:20
Preview
