MemTypeTool GUI v0.3 released!
A project log for Memtype: Open Source Password Keeper
Memtype, an elegant solution to have your credentials stored everywhere.
noel-carriquiNoel Carriqui • 06/22/2016 at 09:53•0 Comments
The MemTypeTool GUI v0.3 has translation support added, for the moment only Spanish translation appart from default English, but if you feel like translating it to another language just copy the es_ES.ts file inside translate directory, use the right name for your language and country so it can be loaded automatically.
Then use lrelease command (from qt) and the .qm file will be generated and used automatically based on your locale settings on the computer.
A windows install instructions has been added to the readme with some screenshots.
https://github.com/oyzzo/MemTypeTool
Hope you like it! :)
Miguel & Noel
