MemType on Tindie back in stock!
A project log for Memtype: Open Source Password Keeper
Memtype, an elegant solution to have your credentials stored everywhere.
noel-carriquiNoel Carriqui • 07/25/2016 at 12:02•0 Comments
We've soldered and prepared more MemType units for the Tindie store!
https://www.tindie.com/products/area0x33/memtype-open-source-password-keeper/
The soldering procedure this time has been the hot plate reflow technique, using the great chipquick solder paste and has been a pleasure!
To apply the solder paste we've used the great syringe provided by chipquick, after some tests and being done the first couple of units it's been super easy to apply the right amount of solder paste to each pad, much easier than expected.
We asked for stencils but they're still on the way, next units will be made using the stencil so we'll compare and share the results.
The weather was great so we decided to doit outdoors! PCB bbq :)
Miguel & Noel
