(Run simulation, here)
@Ted Yapo, you might like this one...
Can you guess what I (likely mis-)perceive it to be?
A project log for Random Ridiculosities and Experiments
Sometimes yah's just gots tah try somethin', regardless of whether it'll become a full-fledged "project"...
I can't get your links to load on my Linux/Firefox computer :-/
huh, same setup here... wonder if it's a regional thing... No matter, I think I failed on this one anyhow.
the simulation website works but your links seem to contain circuit data in a "very expanded form", which might cause troubles, URL have size limitations :-/
url-size-limitation *sounds* reasonable, but, again, it works fine on my computer, which sounds like it's similar in setup to yours... so strange. I didn't make this thing, I'm just using it. An alternative is to copy-paste this wall-o-text in the "import from text" option.
$ 1 1e-13 6.450009306485576 64 2 50
r 624 224 704 224 0 220
t 704 128 768 128 0 -1 0.4633692633311938 -0.3362293463637836 100
t 704 304 768 304 0 1 0.4633692604398858 0.4637706507449084 100
w 704 224 704 176 0
w 768 224 768 144 0
w 768 224 768 288 0
w 704 176 704 128 0
g 768 352 768 384 0
368 768 144 816 144 0 0
r 288 224 352 224 0 50
w 768 80 496 80 0
w 96 80 96 288 0
w 288 224 288 304 0
w 496 352 768 352 0
368 288 224 288 176 0 0
c 704 304 768 352 0 1.8e-11 0.4637706507449084
c 704 128 768 80 0 1.8e-11 -0.3362293463637836
s 576 176 624 176 0 0 false
c 624 176 704 176 0 1e-10 0.01268187086550554
w 576 176 576 224 0
w 624 224 576 224 0
w 576 224 496 224 0
p 704 128 592 128 1 0
w 768 80 768 112 0
w 768 320 768 352 0
r 704 224 704 304 0 0.1
x 600 335 719 338 0 12 Simulating CBE --->
x 538 273 686 276 0 12 prevents oscillation --->
x 270 163 317 166 0 12 Scope1
x 620 110 667 113 0 12 Scope2
x 799 131 846 134 0 12 Scope3
207 976 224 976 176 0 V
207 768 80 768 48 0 V
v 944 288 944 256 0 0 40 0.8 0 0 0.5
g 976 352 976 384 0
r 1024 224 1024 288 0 10000
r 1024 288 1024 352 0 10000
w 1024 224 976 224 0
w 976 224 944 224 0
w 944 224 944 256 0
w 944 288 944 352 0
w 944 352 976 352 0
w 976 352 1024 352 0
207 592 128 544 128 0 V /2
207 1024 288 1088 288 0 V /2
368 944 224 896 224 0 0
x 835 258 909 261 0 12 double-click
x 836 272 922 275 0 12 to change -->
s 160 208 192 208 0 1 true
s 160 240 192 240 0 1 true
w 192 208 208 208 0
w 208 208 208 224 0
w 208 224 208 240 0
w 208 240 192 240 0
r 496 224 496 80 0 10000
r 496 224 496 352 0 10000
w 496 80 240 80 0
w 496 352 240 352 0
c 352 224 416 224 0 1e-11 0.323065952341182
w 416 224 496 224 0
S 144 304 96 304 0 1 false 0 2
w 208 224 288 224 0
w 240 80 160 80 0
w 160 80 160 208 0
w 160 240 160 352 0
w 160 352 240 352 0
s 208 304 288 304 0 0 false
w 144 304 208 304 0
w 160 352 96 352 0
w 96 352 96 320 0
w 96 80 160 80 0
o 14 16 0 2083 1.25 0.00009765625 0 -1 0
o 22 16 0 2082 0.15625 0.00009765625 0 -1 0
o 8 16 0 2083 0.001220703125 0.00009765625 0 -1 0
That's a better way than in the URL (if it works, and I'll try tomorrow)
'course, it helps to throw a load in there, to make things a little more realistic :/
