This will be a description of the steps taken to write and run programs.
1. Program is written in assembler starting at address 0x8400
; ---------------------------------------------------------------------; ; Print out Hello World!!! ; ; ---------------------------------------------------------------------; #include "labels.ass" #target rom ; declare target file format #code $8400,$4000 ; declare main code segment hello_world: ld HL, str_hello_world call print_string call new_line ret str_hello_world defm "Hello World!"+$80 #end
2. Before assembling the program a script gets the symbols used in the monitor so that routines such as 'print_string' can be used. The symbols are saved into labels.ass
zasm conveniently can produces a log file with all the symbols defined.
3. The program is assembled with zasm.
4. Yet another script is called that reads the bin file and outputs commands for the monitor that will write the program to the RAM. The commands saved into a text file.
This is what it looks like:
wa 8400,21 wa 8401,0A wa 8402,84 wa 8403,CD wa 8404,E8 wa 8405,03 wa 8406,CD wa 8407,BF wa 8408,03 wa 8409,C9 wa 840A,48 wa 840B,65 wa 840C,6C wa 840D,6C wa 840E,6F wa 840F,20 wa 8410,57 wa 8411,6F wa 8412,72 wa 8413,6C wa 8414,64 wa 8415,A1
5. 'Picocom' and 'ascii-xfr' are used to send the commands to the monitor.
6. Finally address 0x8400 is called.
This is the result in the serial monitor:
# *** file: -s -l 10 /home/oliver/workspace/z80/messy80/programs/hello_world/hello_world.txt $ ascii-xfr -s -l 10 /home/oliver/workspace/z80/messy80/programs/hello_world/hello_world.txt ASCII upload of "/home/oliver/workspace/z80/messy80/programs/hello_world/hello_world.txt" Line delay: 10 ms, character delay 0 ms wa 8400,21 #wa 8401,0A #wa 8402,84 #wa 8403,CD #wa 8404,F8 #wa 8405,03 #wa 8406,CD #wa 8407,CF #wa 8408,03 #wa 8409,C9 #wa 840A,48 #wa 840B,65 #wa 840C,6C #wa 840D,6C #wa 840E,6F #wa 840F,20 #wa 8410,57 #wa 8411,6F #wa 8412,72 #wa 8413,6C #wa 8414,64 #wa 8415,A1 # *** exit status: 0 #ca 8400 Hello World! Successfuly returned #
