I managed to get my first version of the board working using a PIC24GB002.
For this board, PIC was communicating directly with the AT commands of the ESP (sending AT's and parsing response). the 3 end-points i created were :
/led/clear
/led/print?text=<TEXT>
/led/set-color?color=RED|GREEN|ORANGE
The problems with this board are
- Writing and parsing AT commands on the PIC cost me with precious CPU cycles, which in turn caused the display to flicker every time i sent a command to the ESP over the network. The PIC had a 16mhz oscillator connected to it but even with 16mhz the screen was still flickering ever once in a while when i typed a new message
- PIC24GB002 didnt have enough IO pins to support the 160x24 display (3 IOs for each row + 4 shared across rows = 13 IOs pins needed)
Iv'e decided that for the next test board i will -
- Use a larger PIC - PIC24FJGA006 which have more than enough pins to support the larger 160x24 display
- Remove the parsing and REST request processing from the PIC and move it to the ESP
- as a 'bonus' - i`m gonna to replace the old 16mhz oscillator with a new 20mhz one - which will hopefully eliminate the flickering completely
I came up with this design -
and this board -
Yadid Ramot
