NOSIER
nGoline One Square Inch ESP8266 Relay powered by mains
This is a 1 Square-Inch board containing an ESP8266-12E WiFi module and a relay powered from mains (80V-240V).
This enables you to create a small footprint IoT module powered directly from the outlet.
DANGER! Don't mess with mains unless you now what you are doing!
This board can turn on/off any appliance up to 200W via WiFi
  • 1 × ESP8266-12E WiFi IoT Board
  • 1 × SR086SG-GCT-ND 240V Relay
  • 1 × 425-2853-1-ND Linear Switched Voltage Regulator
  • 1 × LVR055KCT-ND Resetable Fuse
  • 2 × F3466CT-ND Varistor
View all 15 components
  • Hello World!
    nGoline11/11/2015 at 17:05 0 comments
    Just finished the PCB, now it's time to get it done and buy the parts.
    Just because I live in Brazil it's more dificult to deal with shipping, taxes and the crazy conversion rate from USD to BRL!
    Wish me luck!
View project log
Blecky wrote 12/07/2015 at 01:14 point
Just a friendly reminder to please upload your design documents by 23:59 UTC on Dec 8, 2015 to be in the running for #The Square Inch Project
alpha_ninja wrote 12/02/2015 at 00:41 point
This is your one-week reminder to upload design documents: https://hackaday.io/project/7813-the-square-inch-project/log/28566-design-deadline
