Trouble with other joysticks.
07/06/2017 at 15:54 • 1 commentAfter talking with Orion Robots, and him replicating this solution here, he had trouble making this work with other joysticks. This is because when moving the joystick all the way to high or low, the internal resistance of some joysticks is so low that the esp8266 isn't able to sink the current into its GPIO pin. If you experience similar issues, try using this updated schematic.
ESP8266-GAME
12/12/2015 at 09:38 • 0 commentsfollow the project for the ESP8266-GAME over at https://hackaday.io/project/8756-esp8266-game and give a skull if you like it.
Daniel Johnson
