1Step 1
1.) Straighten out a paperclip.
2Step 2
2.) Wrap the paperclip very tightly around a small, 1/8 inch diameter rod or screwdriver.
3Step 3
3.) Slide the coiled paperclip off of the screwdriver or rod.
4Step 4
4.) Snip off each ring from the coil.
5Step 5
5.) Follow your favorite chainmaille pattern, using 2 pairs of needle-nosed pliers.
b1tbang3r
please make a :
more images
look around thingiverse for making some element from wire
you are making fasters
