Ramon here,
i have been working again on the watch a few days ago till now, with 2 main things in mind: framebuffer and extending the battery life
i succeeded in both, mainly in battery life: 370 hour standby (17 hour runtime @ 24mhz) time (no accelerometer yet) (total powerdraw: 1.35mA)
which is like 15 days of standby on a 500mAh lipo!
right now i am working on porting all graphic commands to use the framebuffer.
only downside of the framebuffer is: it consumes half of the teensy 3.2's RAM.
but thanks to rossum's microtouch framework we can still have 9kilobytes of RAM for apps, which is 1/8th more than an Arduino mega!
also, cool thing of the framebuffer is: alpha blending is possible, and some people might have seen a video of me demonstrating it. but for those who didn't, here's the video:
Nice update, I thought you gave up this one :) The "GFX_test_Dots" is captivating, is it custom code or using a library ?
You mentioned you already optimized battery life, but in case you want, you can check Kenvin's new series about Low Power "tricks" https://www.youtube.com/playlist?list=PL0JWuCHXfJ2zjHiHtHUO2AjGQ1pP4Bzab
i simply ported the ili9163c library from sumotoy to work with a framebuffer :)
and i was using deepsleep mode already, which disables almost everything, right now i'm expirimenting with the hibernate function, it now consumes 0.31mA when in hibernation (teensy 3 snooze library)
Cool, I'm looking forward to the future updates.
also, i ditched the azerowatch ecause it just doesn't do it regarding power consumption, or someone else is willing to create a similar low power library for the atsamd21
thanks, i'm currently also discussing with the same guy who designed the zerowatch for this pcb, he's willing to do this, though it will be 4 layers for the pcb (same as zerowatch) and can be ordered at oshpark in the future i hope (also asked if he would opensource the cad files) :)
You mean designing it ? Do you plan to use the teensy directly onto the pcb or customly solder the chips ? The same TFT LCD is available on aliexpress with the flex to solder directly onto the board.
