Lightswitch diagram 1
Portable Network Graphics (PNG) -
84.63 kB -
03/29/2020 at 06:27
Preview
Lightswitch diagram 2
JPEG Image -
32.53 kB -
03/29/2020 at 06:26
Preview
Lightswitch diagram 3
JPEG Image -
68.81 kB -
03/29/2020 at 06:26
Preview
ETS2_124L_NUCLEO_F446RE.bin
Program for running on a Nucleo FR446RE for the Scania Cluster and ETS2 with the 64-bit silas Parker Plug-In.
octet-stream -
35.02 kB -
11/08/2019 at 08:56
Download
component list.docx
PCB for cluster list of components
document -
11.82 kB -
10/14/2019 at 19:47
Download
Tacho Pinout
JPEG Image -
1.95 MB -
10/14/2019 at 18:44
Preview
Tacho with original scania wiring diagram
1.25 MB -
10/14/2019 at 18:43
Preview
Pinout for the PCB to Tacho wires
3.61 kB -
10/14/2019 at 18:43
Preview
Wiring of the cluster to the custom PCB
1.80 MB -
10/14/2019 at 18:17
Preview
schema.pdf
PCB Cluster scheme
Adobe Portable Document Format -
201.80 kB -
10/14/2019 at 18:13
Preview
Scania_EPC_PDF_Dump.rar
This is a Scania EPC Dump of all wiring / Building Diagrams for 4-Series.
RAR Archive -
35.36 MB -
06/05/2019 at 05:49
Download
1.80 MB -
04/18/2017 at 14:36
Preview
inputs1.ino
Nice and clean little Arduino Code to connect up to 10 units to an Arduino Pro Micro. This applies for all 2-wire things like the parking brake lever, horn, switches, exhaust brake etc.
If you connect for example a "Horn" to input 2 and GND on the Pro Micro, this code will output the keyboard letter "a". Input 3 and GND will output a "b" and so on and so on. Simply modify the letter of choice and you can use this code for almost anything and any simulator.
ino -
1.83 kB -
04/07/2016 at 09:29
Download
Direction_Indicator_1.ino
Scania Direction Indicators file or Pro Micro
ino -
6.67 kB -
03/27/2016 at 12:07
Download
Pro_Micro_HID_A_to_I_Final.ino
Arduino IDE code for 9 switches connected to a Pro Micro or Leonardo
ino -
6.59 kB -
02/23/2016 at 18:46
Download
Retarder_Final.ino
Arduino IDE code for the Retarder Scania Part 1349967
ino -
1.49 kB -
02/23/2016 at 18:42
Download
ACC_Final.ino
Arduino IDE code for the Cruise Control Scania Part 1402449
ino -
1.40 kB -
02/23/2016 at 18:39
Download
