I've created a Dual Core Complex that now has the Trinity Net block in it.
Then created a better frame work which instantiated this 'node' in a the three dimensional matrix.
The matrix is sized as a 2x2x2 which gives a total of 16 cores.
Run a test program but now back to the original issue with the previous array of cores which was that it takes a long time for anything to be simulated.
10 us takes 1 minute 40 seconds as each signal is recorded. I really need to get the latest version of the simulator to see if I can reduce the number of signals recorded.
