I've now updated the top level so that there is a Master Node and a Slave Node. The Master Node Instruction memory will take an image of one instruction stream and the Slave Node take a different instruction stream. This allows me to create a kind of Job Dispatch algorithm.
While testing this I discovered a couple of issues with respect to the assembler which are now fixed.
The next thing is to update the array so that each node has a Von Neumann Memory. This will allow program code rather than just data to be distributed.
