1Step 1
I ordered 10 board with only these components assembled during pc production. Seeed Fusion services were utilized and I sent them the board Gerber files and this short BOM:
Designator Manufacturer Part Number Quantity C5 16TQC10M 1 C6 T491B106M006AT 1 U2 PCA9685PW/Q900,118 1 U1 TB6612FNG,C,8,EL 1 C1,C2,C3 C2012X8R1H104K125AA 3 R1,R2 ESR10EZPJ104 2 R3,R4,R5,R6,R7,R8,R9,R10,R11 ESR10EZPJ221 9 LED1 LTST-C170KFKT 1 C7 GRM21BR71C105KA01L 1 R12 ESR10EZPJ473 1 I purchased most the other components shown here and assembled my board. A complete BOM is in the files section of this post.
2Part Insertion
Find a way to raise the board for part insertion. Turn board over and solder each step. I use another blank board to hold the parts down while I flip the board. These photos are in the order you will want to use from shortest to tallest part.
3Add the Arduino Headers first and Vstamp first.
4Next are the servo and analog pins
I ordered some 3 position headers so I didn't have to break apart a header but you need 39 to a single 40 pin header will work just fine for this step
5Next is the 5V switching regulator. Note the orientation...
6Last are the screw connectors
Luke J. Barker
