QuadRotor testBed for localization and mapping
I am trying to build a test bed for trying out localization and mapping algorithms.
I am trying to build a Quadrotor testBed for trying out localization and mapping projects. The current alternatives are very expensive for me which is the reason I came up with this project. My interest lies in developing a testBed that can allow people to focus on the algorithms rather than getting bogged down by the infrastructure required to implement the algorithm.
Quadrotors are very complex but interesting vehicles. I have been a huge admirer of these machines. Owing to my interest in Robotics, I needed to play with certain applications of these machines.
Currently, I feel the way to implement this idea would be to use a ardupilot on a beaglebone blue. Ardupilot is an open source software that can help me work on the specifics of my project rather than dealing with control issues. Along with the beaglebone blue, the copter would comprise of a Scanse sweep Lidar from sparkfun for generating the Occupancy maps. This serves as a platform to conduct reserch on the platform.
Introduction:
This project aims at building a Quadrotor test bed for trying out autonomous algorithms. The quadrotor is a fairly complex machine which can serve as a useful tool to test out new algorithms for your research. I intend to test localization and mapping algorithms on this test bed.
Localization:
For mobile devices, the ability to navigate the environment is crucial. To navigate a complex environment with unknown obstacles, it becomes paramount to know where the robot is located. This need to know where the robot location is a highly complex subject which can be solved through a variety of algorithms. The goal for the robot can only be achieved if the localization system helps the system navigate without crashing into unknown territory.
Hardware used:
A Quadrotor kit : https://www.hobbychimp.com/products/hobbypower-x525-v3-quadcopter-foldable-kit-w-sunnysky-1250kv-motor-mini-kk2-15-fight-control-simonk-30a-esc-for-multicopter?gclid=CMW4ib7U49MCFVKUfgodVQwMRg
Scanse Sweep Lidar: https://www.sparkfun.com/products/14117
BeagleBone Blue : https://www.mouser.com/ProductDetail/BeagleBoard/BBBLUE/?qs=MoCBKJu1Jj2UWBPau58zsg%3D%3D&gclid=CjwKCAjwypjVBRANEiwAJAxlIgIghDeMgFxQJT4dzTU4es7bIhxZ80gABUUASGpf3iM_0YoYu6UOahoC1j0QAvD_BwE
Software used:
ROS on beaglebone blue
Point CLoud library
Ardupilot : https://github.com/mirkix/ardupilotblue
Approach:
The aim of this project is to implement certain open source ROS algorithms on the test bed. The test bed itself can be assembled using the components. I intend to work on ICP and particle filters on the Quadrotor. The beaglebone blue would be used to run the Ardupilot on it providing motion commands to the rover. I intend to install ROS indigo on the platform so as to simultaneously work on the Ardupilot and ROS. The scans or the pointcloud data would be generated by the Scanse sweep module which have the necessary ROS drivers https://github.com/scanse/sweep-ros.
Iterative closest point (ICP) is an algorithm employed to minimize the difference between two clouds of points. ICP is often used to reconstruct 2D or 3D surfaces from different scans, to localize robots and achieve optimal path planning.
The experiments that I need to conduct is basically ICP scan matching and registering. I am trying to get the pose of the vehicle using the scan registering process. The pose can help me get the correct position of the vehicle in the unknown environment. To implement the scan matching, I would be using the Point cloud library. Point cloud library is an easy interface for implementing localization algorihtms. ICP implementation from the PCL can help me get the maps necessary for the mapping process.
The position of the copter as derived by the Ardupilot controls can be published on a ROS node. This vealue is then used to filter the value that we get from the scan matching. The updated position can be used as the position of the rotor.
Deliverables:
The project deliverables would be a software and hardware solution integrating Ardupilot and ROS for implementing localization and mapping modules from ROS into Ardupilot.
  • 1 × BeagleBone Blue Controller
  • 1 × Parrot Ar Drone 2.0
  • 1 × Scanse Sweep Lidar
  • Octomaps
    int-smart • 07/20/2018 at 01:13 • 0 comments
    This post deals with the Octomaps library which deals with creation of an efficient way of storing, querying and include uncertainty in measurements. Octomaps are data structures t represent 3d space. There are many approaches for modelling 3D space in the robotics domain by creating voxels.
    Octomaps differ from them as it does not suffer from space constraints and the problems such as inability to model unknown and free space. Octomaps can model uncertainty in obstacles in the occupancy grid by incorporating probabilistic updates of the occupancy maps. Octomaps can be used to represent voxels at different resolutions. The datastructure used for their implementation are octrees.
    Every Octree has eight children. Basically the root of the tree is the area that you are modelling. This region can be unknown initially as the restriction here is the size that you want your octree to be. If the size of the Octree should be small then a dynamically exploring a bigger area would yield leaves with coarser resolutions and vice versa. To include free space in the modelling Octrees explicitly include two types of node: Occupied and Free. Unknown nodes are not generated. Each root is a volume in real world. The children are obtained by dividing the root volume into eight equal parts (voxels) something similar to the four quadrants that we normally use in 2 dimensions. The occupancy values are updated using some distance measurement sensor. The voxels containing the endpoints of the sensor readings are marked as occupied in a discrete map and updated according to some predefined formula in a probabilistic occupancy grid. The region on the ray between the sensor and the endpoint is marked as free and the octree is updated accordingly.
    Currently I am looking at ways to represent the Lidar scans that would be acquired using Octomaps and get a 3D map for the environment. Octomaps are purely for generation of maps. Octomaps are however flexible as they are available as a opensource C++ library which can be included in any C++ project. I am also looking to study the Hector-SLAM package for ROS which is restricted to ROS from what I know. Hector-SLAM though includes mapping, localization which is highly desirable if you want to get started with your planning projects. Currently I am looking to study both of them and try to implement some examples
  • SITL
    int-smart • 07/11/2018 at 12:29 • 0 comments
    Currently I am working with simulating the project in ArduPilot and then taking it to hardware. ArduPilot SITL is one way to simulate the flight and the sensors. I am pretty sure that the SITL does have a Laser scanner simulator but am not sure what is its field of view. The process to download and run SITL on a Ubuntu 16.04 is as follows:
    • Open Terminal and clone the git repository.
    git clone git://github.com/ArduPilot/ardupilot.git
    cd ardupilot
    git submodule update --init --recursive
    •  The next step depends on the operating system that you are using. Go to the installation instructions for your OS on Ardupilot website for more details. For Ubuntu 16.04 you just need to run a script:
    cd ardupilot
    cd Tools/scripts
    ./install-prereqs-ubuntu.sh
    •  Add the following to the end of your bashrc file and source it.
    export PATH=$PATH:$HOME/ardupilot/Tools/autotest
    export PATH=/usr/lib/ccache:$PATH
    . ~/.bashrc
    • Start the simulator.
    cd ardupilot/ArduCopter
    sim_vehicle.py -w  #to load the default parameters
    sim_vehicle.py --console --map
     The copter can be run in several modes:
    1. Guided: To run in Guided mode do the following.
    mode guided
    arm throttle
    takeoff 40
    For more detailed commands and information goto:
    http://ardupilot.org/dev/docs/copter-sitl-mavproxy-tutorial.html
    2. Auto: For navigating the copter in Auto mode do the following:
    wp load ..\Tools\autotest\copter_mission.txt
    arm throttle
    mode auto
    rc 3 1500
  • LIDAR message
    int-smart • 07/11/2018 at 12:14 • 0 comments
    I am planning to use ROS to interface the Lidar with the copter. The LIDAR messages are published using the message format defined in the sensor_msgs/laserscan message type in ROS. The message consists of :
    std_msgs/Header header
    float32 angle_min
    float32 angle_max
    float32 angle_increment
    float32 time_increment
    float32 scan_time
    float32 range_min
    float32 range_max
    float32[] ranges
    float32[] intensities
    The angles are in radians. angle_min is the start angle from which the LIDAR starts taking observations in one scan. It then takes observations by incrementing the angle with steps equal to angle_increment until it reaches the angle_max when the scan completes. The time between two scan is equal to time_increment. Scan_time is the time to complete one scan in the FOV defined for the LIDAR. Range_min and range_max are the minimum and maximum values that the LIDAR can detect. Ranges give you the distance observation that has been calculated by the LIDAR.
  • Extended Kalman Filter
    int-smart • 03/24/2018 at 03:39 • 0 comments
    I had explained Kalman filter in the last post. What happens when the motion model and observation model is not linear. In robotics, the linear case occurs rarely. So algorithms that can handle non-linear models can be used to localize. The Extended Kalman filter is one such algorithm.
    The observation and motion model for non-linear case can be represented by:
    Here g and h represent the non-linear model. The other notations are the same as those in Kalman filter equations. After applying the non-linear models to the state x which in our case is a gaussian, we get a distribution that is not a gaussian. We try to approximate this distribution with a gaussian to get the final state. This is done by using Taylor expansion which linearizes the function at the mean.
    Using first-order Taylor expansion at the mean we can approximate the motion and observation model with the following linear model:
    Let the jacobians for motion and observation model be,
    Substituting the above linear model into the Bayes filter equations we get,
    Replacing the Kalman filter equations with the new linear model we get:
    The above equations show the Extended Kalman filter where we just linearized the non-linear modelwith Taylor expansion. This method however performs linearization just at the mean due to which it is not representative of the actual non-linear model. It works well in cases where the non-linearities are moderate.
  • Kalman Filter
    int-smart • 03/23/2018 at 23:25 • 0 comments
    Intoduction:
    Kalman filters can be intrepreted as Bayes filter with the gaussian linear case. There application range from economics to weather forecasting to satellite navigation. If models are not linear the beliefs do not remain gaussian and we can not work with a simple kalman filter.
    A multivariate Gaussians can be described:Let v be a multivariate gaussian distribution:
    The marginal of x can be defined as:
    The conditional of x with respect to y is:
    The kalman filter linear and observation models can be thus represented by:
    where x represent the motion model and z represent the observation model. Here the motion noise epsilon is zero mean gaussian with covariance R and the observation noise is zero mean with Q covariance.
    Substituting these values in the Bayes filter motion and observation models we get,
    The above values can be substituted in the prediction and correction step below:
    to get the final Kalman filter equations described in the algorithm below:
    The first two equations show the predictions for the mean and covariance of the state and the last two equations give us the final belief of the state considering the observations. Once again, all of this is just applicable when we have linear motion and observation model. For non-linear models we consider the Extended Kalman filter that I would be explaining in my next post.
  • SLAM
    int-smart • 03/16/2018 at 03:14 • 0 comments
    Simultaneous Localization and Mapping (SLAM):
    SLAM is a probabilistic technique to construct and update maps for navigation while localizing the object pose in the map. The problem appears to be a chicken and egg problem as to localize the vehicle we need a map and to update the map we need to know the pose of the vehicle. This problem can be solved through multiple approximate techniques such as Extended kalman filters and Particle filters.
    The problem can be formulated mathematically as finding:
    Input: robot's controls inputs u and observations z.
    Output: Map of the environment m and the pose of the robot x
    This can be done using bayes filter. Bayes filter is a two step process: Prediction and Correction.
    Predicton step predicts the state of the vehicle using the motion model, control inputs and previous belief while the correction step reduces the uncertainty using the observation model. The motion model describes the distribution of the current state of the system given the control inputs for this time step and the previous belief of the pose of the vehicle. This can be represented mathematically as:The predicted state of the system is :
    The Sensor model or the Observation model is responsible for reducing the uncertainty that is introduced by the random nature of the problem. The predicted state is:This belief value is the current pose of the system.
    There are multiple ways to implement the Bayes filter:
    • Kalman Filters which deals with gaussian distributions and linear models
    • Particle Filters which deal with non-parametric arbitrary models
    Kalman filters deal with the linear gaussian case. By linear we mean a linear model and by gaussian we mean gaussian noise is associated with the pose and observations.
  • Scan Matching and Registration
    int-smart • 03/14/2018 at 01:25 • 0 comments
    ICP (Iterative closest point) is a popular range data processing method that can be used for range registration. Given two sets of slightly overlapping point clouds the ICP computes the registeration of one scan over the other in an iterative fashion.
    Mathematically we can construct the problem as:
    Given two point setwe need to find the translation and rotation that
    If the correct correspondances are known, we can calculate the alignment using SVD. It can be done using first subtracting the value of the center of mass of the two point clouds from the points in the set and then taking the SVD of the accumulation matrix defined by:The rotation matrix is given by
    The registeration algorihtm is briefly described in the following:
    • For each point in the first scan, find the closest point in the second scan.
    • Find the relative position of each scan so that the MSE (Mean squared error) calculated as the mean of the distance between the closest points is minimized.
    • Repeat until the MSE is below certain threshold or stops changing.
View all 7 project logs
  • 1
    1. Preparing the BeagleBone Blue
    Preparing the software environment of BeagleBoneBlue. Installing required packages
    Step 1:
    sudo apt-get install python-pip python-setuptools python-yaml python-distribute
    Step 2:
    sudo apt-get python-docutils python-dateutil python-six
    Step 3:
    sudo apt-get install libconsole-bridge-dev liblz4-dev checkinstall cmake python-empy python-nose libbz2-dev libboost-test-dev libboost-dev libboost-program-options-dev libboost-regex-dev libboost-signals-dev libtinyxml-dev libboost-filesystem-dev libxml2-dev libgtest-dev
  • 2
    2. Intsalling ROS on the blue
     Installing ROS kinetic or Indigo on the Blue
    Step 1:
    sudo sh -c 'echo "deb http://packages.ros.org/ros/ubuntu jessie main" > /etc/apt/sources.list.d/ros-latest.list'
    wget https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -O - | sudo apt-key add -
    Step 2:
    sudo apt-get update
    sudo apt-get upgrade
    Step 3:
    sudo pip install rosdep rosinstall_generator wstool rosinstall
    Step 4:
    sudo rosdep init
    rosdep update
View all instructions
