1Step 1
Cut one of each of the following files.
2Step 2
Glue the top of the body to the middle of the body.
Protip: Using the neck to line two pieces up is a good idea.
3Step 3
Glue the back of the body on, this is made easier using a large clamp with one side on the neck pocket for alignment.
4Step 4
Sand the sides of the body with increasing grits of sandpaper, until you're satisfied.
5Step 5
Apply your sanding sealer and finish.
6Step 6
Bolt on your neck, with the tuners installed.
7Step 7
Wire the electronics in whatever interesting configuration you want.
8Step 8
Play your new guitar
Michael Moskie
