Hackaday.io Hackaday.io
Sign up Log in
Dodge Dakota Solar Truck Tent
Diy Truck tent for the Dakota.
emericaEmerica
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
19 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
344
3
19
3
Team (1)
  • emericaEmerica
Join this project's team
This project was created on 04/19/2014 and last updated 12 years ago.
Details
Log In/Sign up to comment
Sign up with Github
OR
Mike Szczys wrote 04/25/2014 at 19:40 • point
Nice! It's like the tent for the Chevy Avalanche... but you know, this one actually makes sense!
Emerica wrote 04/22/2014 at 07:29 • point
4 bolts hold it to the box of the truck, 10 mins to take on/off.
2 Straps hold it all down and secure while in transit.
As is it's heavy because of the wood and bedframes I scavenged. So it helps to have two people to install it as is.
Heavy winds were fine so far, much stronger than I had expected. But the tarp zippers and a few places are a little leaky. Nothing horrible yet but I will be making another tent top with good material, using the camo tap pieces as a pattern. I may have it professionally done.
For a tent made out of tarps, well I think I did ok. :)
Still room in the truck box for standard large size tupperware and toughpak bins.
I wanted something I could pull over anywhere, side of the road if need be, in the rain, and not be soaked by the time I'm finished. With this, I pull the two straps, pull off the cover and use that as a umbrella, grab the ladder and pull. Whole thing folds open and you can climb in from either side.
5 inches of foam both sides.
Bed frames I found at the community garbage bin, cut at welded them up, made some hinges which I need to extend a little due to the excess comfort foam :)
The wood sides, I dunno..... we'll see
Emt tubing for the poles, cheap. but very effective.
If you are in the States or better Australia you'd probably get a cheaper premade rooftop tent
locally and mod it to your needs.
I have work to do on this for this season and shall document my changes :)
Jasmine Brackett wrote 04/22/2014 at 04:18 • point
This is great. I've been thinking about something like this for a while. More details please. How does it hold up in strong wind? Do you keep it attached all the time, or how easy is it to install/uninstall?
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Dodge Dakota Solar Truck Tent", please tell us the reason.
Send message
Remove Member
