1Step 1
Acquire all the items needed.
2Step 2
Install a distro compatible with the Pi 2 on the MicroSD Card.
3Step 3
Put Pi Together and connect all peripherals.
4Step 4
Boot and set up Pi.
5Step 5
Download Bittorrent Sync.
6Step 6
Start Bittorrent Sync and access the program via WebUI (Address located in Readme.txt)
7Step 7
Go through the setup and set the destinations for the folders that you want to be able to sync.
8Step 8
Send QR code or secure key to phone or other device.
9Step 9
Once that is done, you should be able to access data, from your USB/HDD/SSD connected to the Pi, from your phone.
