By supplying 5 volts to the wiper of the modded pot we can throw a voltage or a signal to one of the two pins just like a SPDT switch. I tried tying the wiper to ground and throwing ground to each pin but it wasn't as fluid as using transistors proved to be.
Solderking
Ops.. didn't realized before that you that you have reworked the pots. Either way, for future projects you can use the trick of cutting the transistors and you will won't need to rework the pots :)
