Hackaday.io Hackaday.io
Sign up Log in
Poor Man's Raspberry Pi Turtlebot
Autonomous ROS-powered robot vacuum cleaner project
fuzzie360fuzzie360
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
10.4k views
3 comments
1.6k followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 3
View Gallery
10.4k
3
1.6k
34
Team (1)
  • fuzzie360fuzzie360
Join this project's team
  • Autonomous Navigation Video
hardware
ongoing project
raspberry pi Roomba kinect ros Turtlebot
Related lists
Roomba Projects
Projects based upon iRobot's vacuum platform
111
111
This project was created on 12/01/2015 and last updated 5 years ago.
Description
This is a Poor Man's Turtlebot
End goal: Vacuum my Roomba hostile apartment
Software
-Raspberry Pi 2: ROS Indigo on Arch Linux for Arm
-Laptop: ROS Indigo on Ubuntu 14.04 LTS
Installing the Turtlebot stack on the Pi is a very involved process. There are too many steps for me to do a quick guide, but the information is all online. Contact me if you run into any trouble as I've encountered a lot myself.
Components
  • 1 × Raspberry Pi 2
  • 1 × Roomba 780
  • 1 × Kinect for Xbox 360 + Hacked USB Splitter
  • 1 × Minigorilla Multivoltage battery
  • 1 × 7pin Mini DIN + Jumper Wires + USB UART
Project Logs
Collapse
  • Autonomous Navigation Test
    fuzzie360 • 12/01/2015 at 14:33 • 0 comments
View project log
Log In/Sign up to comment
Sign up with Github
OR
jonathan.liang wrote 08/01/2017 at 19:35 • point
Hi fuzzie360, I am trying to create a similar solution using Ubuntu 16.04, Intel RealSense R200, Intel UP Board, and the iRobot Create 2 Programmable Robot. I was wondering if you had any links to the resources you found helpful, especially in regards to 3D mapping and SLAM. Thank you!
-Jonathan
Wilton R Cruz wrote 05/02/2017 at 01:57 • point
Can integrate phyton with ros ?
Lucas wrote 02/22/2017 at 17:08 • point
Hello,
I've installing the same target environment software... But my turtlebot don't work...
When I try "roslaunch turtlebot_bringup minimal.launch" :
I have this error  :
[ERROR] [WallTime: 1487674200.166287] Failed to contact device with error: [Distance, angle displacement too big, invalid readings from robot. Distance: 0.00, Angle: -420.89]. Please check that the Create is powered on and that the connector is plugged into the Create.
Do you have a solution for this issue ?
Thanks !
Jérôme
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Poor Man's Raspberry Pi Turtlebot", please tell us the reason.
Send message
Remove Member
