Pocket Brute
Bastardizing a pigrrl with a C1111 chip
A completely open source Hardware and Software hobby project using a Pigrrl, a C1111 chip, rtl-sdr, gqrx, opensesime and other software.
An all-in-one gaming machine that can be used to analyze, decode, and brute force RF
Play Mario, or analyze RF? Why not both!?
In this just-for-fun project I am bringing together some of the communities favorite hardware to make one great all-in-one tool.
  • 1 × http://www.adafruit.com/products/2510 pigrrl kit $99.00
  • 1 × Pigrrl can be found to 3d print online, or buy off of etsy original nintendo, or 3dprinted $30.00
  • 1 × C1111 chip, or Yard Stick One Can be found with a google search $100-$125
  • 1 × RTL-SDR $20.00 dongel should work well
  • 1 × USB HUB Prices range between $5-$20
View all 7 project logs
  • 1
    Step 1
    Gut the Gameboy if you did not purchase a 3d printed version.
  • 2
    Step 2
    Cut excess tabs (not the screw holes!) to free-up room. Save the main board, you can still use that.
  • 3
    Step 3
    Cut the main board in half ware you can still use the 2 pre-drilled screw holes to mount the board. Make sure you do not cut off the button contacts. You will need those as placement for your buttons.
View all 4 instructions
Rich text editor
