Getting Back Into The Swing
02/18/2016 at 16:48 • 0 commentsI have never been a procrastinator, however I have fallen off the project wagon as of lately. I will be posting updates and hopefully a prototype by the end of next month.
Cheers!
So Much To Do-So Many Holidays
12/21/2015 at 15:22 • 0 commentsCan't wait for the holidays to be over that way I can get back to my many projects.
Happy Holidays!
Thanks to ldn0l
12/09/2015 at 17:12 • 0 commentsI would like to publicly thank
ldn0l
for sharing information I was not aware of. Apparently you can already transmit on the raspberry pi without using an external module. (source) http://www.rtl-sdr.com/transmitting-fm-am-ssb-sstv-and-fsq-with-just-a-raspberry-pi/
This will come in handy once I decide to make an all-in-one encasement for the project.
Thank you!
Gesture Input
12/04/2015 at 17:31 • 0 commentsThinking about using gesture input for command line. Simply draw a command in PiTfT touchscreen terminal if you want to launch something not included in the gui. I love the open source community for creating all the neat stuff that I don't have to.
Gesture Input info can be found here.
New Help
12/02/2015 at 19:28 • 0 commentsI believe I found help to make the software a little more aesthetic. I will publish it as soon as it is finished.
To Ir or not to Ir
12/01/2015 at 19:13 • 0 commentsI may add an IR option.
I am by no means a programmer
12/01/2015 at 19:01 • 0 commentsStarted the front end of the software (python), I am by no means a programmer.
Gutted original Gameboy, however I may just order a 3d printed one and add a usb hub.
