I went ahead and dumped the files to the Dropbox for the MTD partitions.
https://www.dropbox.com/sh/adups6kczg65138/AACquDl-FP1ZT0KB1yB-4aGia?dl=0
# cat /proc/mtd
dev: size erasesize name
mtd0: 00040000 00010000 "boot"
mtd1: 000c0000 00010000 "config"
mtd2: 00480000 00010000 "rootfs"
mtd3: 00a80000 00010000 "app"
More to come....
@Neil Cherry right on the main page there is a link to the dropbox on the left hand side. Here is the link:
https://www.dropbox.com/sh/vvlclp0wil7qxx3/AABdxK_0cv1BYp6nzLCwY8SLa?dl=0
Sent you a PM to get your email to add you to it to have write privs.
I also got the SDK toolchain building.. I can actually build a kernel with it! Not that I have tried yet. But its an interesting thought. It looks like the sample code (posted in the dropbox) also has code for image detection and using the camera? I have not fully wrapped my head around the video kernel modules yet nor the code. I am not sure I understand how the SDK came with the camera code / support? Unless the Hi3518 is specifically developed for a video camera application. Kind of like how the RPi has the display port built in... Not a great analogy but you might get what I am saying :)
I haven't gotten as far as building the tool chain. I did try to connect to nfs but that failed (missing kernel module on the camera?). I wouldn't start with the kernel, but I would start with a simple hello world. Then you'll know if you have something that works with the camera. from there w can kill App8518and message and run the sample application to learn what it can do. The App8518 seems to do an awful lot.
In the drop box? I only have the link for the mtd file.
@Neil Cherry roger that "hello world" its my plan too. Just get a binary compiling and then xfer it over and make sure it works. I have been using ftp to do all file sharing. So as far as I can tell it looks like the Hi3518 is a SoC with a camera on it (or interface for a camera). Very interesting. I am not exactly sure why they did kernel modules for a static device but whatever. I will keep you updated on my progress. I am about to get smashed with 30" of snow tomorrow (I am in the DC metro area) so I may be online or not :) I might have some time to play however!
Very cool! My funlux-cap.exp script pulled the img from my camera. The mtd1 & mtd3 are different between your's and mine. The config could be because we have different setups.
