Dumping the MTD Partitions
01/21/2016 at 03:21 • 5 commentsI went ahead and dumped the files to the Dropbox for the MTD partitions.
https://www.dropbox.com/sh/adups6kczg65138/AACquDl-FP1ZT0KB1yB-4aGia?dl=0
# cat /proc/mtd
dev: size erasesize name
mtd0: 00040000 00010000 "boot"
mtd1: 000c0000 00010000 "config"
mtd2: 00480000 00010000 "rootfs"
mtd3: 00a80000 00010000 "app"More to come....
Initial rooting (or read that as loggin in) and poking around
12/02/2015 at 19:16 • 2 commentsThere is a 3 pad test point on the other size of the main board. It is 3v3 ttl serial. tx rx gnd. Solder a few tiny wires to each pad then hook up to a ttl 3v3 usb to serial ( I use the prolific ones) and open a serial terminal (coolterm etc) 115200 8N1. I did place a dab of hot glue to hold the wires in place as to not pull the test point's pads right off of the pcb. I forgot to take a picture of it first. I have another camera on order and will post some pics when it gets in.
This will drop you to a root shell.... Heres some boot messages.. The full boot messages are in the dropbox link.
U-Boot 2010.06 (Apr 28 2015 - 09:46:30) Check spi flash controller v350... Found Spi(cs1) ID: 0x01 0x20 0x18 0x4D 0x01 0x80 Spi(cs1): Block:64KB Chip:16MB Name:"S25FL129P1" MMC: MMC FLASH INIT: No card on slot! In: serial Out: serial Err: serial No mmc storage device found! Hit any key to stop autoboot: 1 ... 0 16384 KiB hi_sfc at 0:0 is now current device cramfs load file : /boot/hikernel ### CRAMFS load complete: 2409600 bytes loaded to 0x82000000 ## Booting kernel from Legacy Image at 82000000 ... Image Name: hilinux Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2409536 Bytes = 2.3 MiB Load Address: 80008000 Entry Point: 80008000 Loading Kernel Image ... OK OK Starting kernel ...There is a really annoying feature that they felt the need to leave in place. All print statements from ./App3518 program seem to spit out to the tty. And its a very chatty program. However it does give you a glimpse into some of the communications with the "MeShare" streaming video service. Observe....
Dec 2 14:02:09 <P2P>: web.cpp[471]web_report_upnp:recv:{"result":"ok","data":[],"addition":""} Dec 2 14:02:09 <P2P>: device_operation.cpp[744]p2p_send_cover_pic:begin upload cover picture for channel[0]... Dec 2 14:02:09 <P2P>: web_task.cpp[42]SetUrl:http://192.241.59.218:80/factorydevice/picture_report Dec 2 14:02:09 <P2P>: web_task.cpp[83]AddPostString:tokenid:p4yL5zwYSQRL8vcCNUbx9v12bmKcQF Dec 2 14:02:09 <P2P>: web_task.cpp[83]AddPostString:channel:0 Dec 2 14:02:09 <P2P>: web_task.cpp[93]AddPostPicture:image_name:/tmp/cover.jpg Dec 2 14:02:09 <P2P>: web.cpp[402]web_report_picture:recv:{"result":"ok","data":"","addition":""} Dec 2 14:02:09 <P2P>: device_operation.cpp[942]p2p_is_timezone_set_by_meshare:timezone America/New_York, America/New_York Dec 2 14:02:09 <P2P>: web_task.cpp[42]SetUrl:http://192.241.59.218:80/factorydevice/gettimezone?tokenid=p4yL5zwYSQRL8vcCNUbx9v12bmKcQF Dec 2 14:02:09 <P2P>: web_task.cpp[252]SetConnectTimeout:[10] Dec 2 14:02:09 <P2P>: web.cpp[425]web_get_timezone:recv reply:{"result":"ok","offset_seconds":"-18000"} Dec 2 14:02:09 <P2P>: web.cpp[434]web_get_timezone:get timezone:-18000 Dec 2 14:02:09 <P2P>: device_operation.cpp[905]p2p_set_timezone_offset[1170719936] Dec 2 14:02:11 <P2P>: p2p_sip.cpp[148]keep_alive_timer_func:keep alive timeout, resend ! Dec 2 14:02:11 <P2P>: p2p_sip.cpp[120]send_keep_alive:send_keep_alive:{ "MethodName": "Option.update", "TokenId": "p4yL5zwYSQRL8vcCNUbx9v12bmKcQF", "DevId": "ZMD00ID02206860", "UserType": 2, "Interval": 90 } Dec 2 14:02:11 <P2P>: p2p_sip.cpp[40]p2p_keep_alive_cb:reply:{ "ResultCode": 0, "ResultReason": "ok", "CmuId": 1001000000 }The program generating all of these print statements is App3518 which I tftp'ed off of the device and posted in the dropbox link. There is also a message file which I am unclear of what it is doing.
ril3ys-MBP:Zmodo Reversing ril3y$ file message App3518 message: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), stripped App3518: ELF 32-bit LSB executable, ARM, version 1 (SYSV), dynamically linked (uses shared libs), stripped
ril3y
