CO2 Data fetch
03/21/2018 at 21:10 • 0 commentsthe first step of the project is to obtained the co2 level data. To do this, I choose to use the HTTPThing app from thingspeak, that allow to fetch data from every site and make it disponible trough an API.
The MCU that i choose to use is the well know ESP8266. Thanks to the ESP8266HttpClient library i can simply send a GET request to the thinghttp link and receive the daily data from www.co2.earth.
#include <ESP8266WiFi.h> #include <ESP8266HTTPClient.h> const char* ssid = "MYWIFI"; const char* password = "*******"; void setup () { Serial.begin(115200); WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(1000); Serial.println("Connecting.."); } } void loop() { if (WiFi.status() == WL_CONNECTED) { //Check WiFi connection status HTTPClient http; //Declare an object of class HTTPClient http.begin("http://api.thingspeak.com/apps/thinghttp/send_request?api_key=YAOX15VANMLMYH4S"); //Specify request destination int httpCode = http.GET(); //Send the request if (httpCode > 0) { //Check the returning code String payload = http.getString(); //Get the request response payload String todaydate = payload.substring(62,76); String todayco2 = payload.substring(118,128); Serial.print(todaydate); Serial.print(" CO2 Level: "); //Print the response payload Serial.println(todayco2); httpCode == 0; } http.begin("http://api.thingspeak.com/apps/thinghttp/send_request?api_key=3TKGGW5Z5CHH7G0S"); //Specify request destination httpCode = http.GET(); //Send the request if (httpCode > 0) { //Check the returning code String payload = http.getString(); String agodate = payload.substring(36,50); String agoco2 = payload.substring(92,99);//Get the request response payload Serial.print(agodate); Serial.print(" CO2 Level: "); //Print the response payload Serial.println(agoco2); //Print the response payload } http.end(); //Close connection } delay(30000); //Send a request every 30 seconds }
However co2.earth only maintain data histories about last year. So for the decade CO2 data i will use a text file downloaded from noaa server that contain world CO2 data from start of 20th century.
