The last PCB, fresh off the mill. This is the lower decoder board. It replaces the two separate decoders I made earlier, because I had to add extra circuitry for the carry logic.
Here it is after soldering.
Those diodes are a real challenge to do consistently. Here is a view from the back of the clock. I had to transfer all the PCBs to a new carrier board (the piece of MDF), without disturbing the delicate wiring. I removed the flip-flop boards to make it easier to handle. You can see I just started wiring in the new lower decoder board.
And there it is, in all it's warm glowing glory. Completely functional, although the wiring needs some work. This is a major milestone for me. The first time all the components are in place and everything seems to be working. Now I can start designing the plexiglass frame that it will be mounted in.
That's it for now. Thanks for reading! Cheers.
Dave Gönner
Nice looking clock!
Are you planning on making the design files available? Artwork, source code, etc.?
I would be interesting in making one of these.
It sure is fantastic to look at, and to listen to. Nice to hear that you like it. The horrible camera doesn't do it justice in high-res ;-)
https://cdn.hackaday.io/images/1277361542642581418.jpg
I had to dig into the HTML to find the large-size picture of the whole clock, it's a crazy sight !
Great job !
YAY !
