Franck just spotted a pretty fumble : I have overlooked the bulk capacitors before and after the LP2981.
I think I assumed that the voltage stability was not critical but usually I am very generous with capacitors.
The other problem is : is there any room left ?
You can replace all the 0.1uF decoupling caps with 1uF ceramic caps as a way to increase the bulk value. Leave the 0.1uF in if there are any high speed chips.
For low frequency work (as in the 10-20MHz or below), it won't make much of a difference.
Sorry gave you bad advice. Turns out that the LP2981 doesn't like ceramic caps because of their low ESR. So you might have to find some small tantalum/electrolytic caps for the output bulk caps.
I supposed so, thanks for confirming ! I'm running out of space...
The pin out of LP2981 is the same as Microchip MIC5245 which is compatible with ceramic caps. There might be other parts that are compatible too.
