This capacitive sensor is RUBBISH
11/15/2016 at 19:04 • 0 commentsThis capacitive sensor is RUBBISH I now use a BLTouch 10000% better than false zero from #capacitive sensor
NOTE This FAILED!!!!
02/23/2016 at 09:36 • 2 commentsNOTE This FAILED!!!!
LJC18A3-B-Z/AY PNP NC 3-Wires 10mm Capacitive Proximity Sensor Switch DC 6-36V
It
a) Seemed to give different distances depending whether it was on the right hand side of the Print bed of the left hand side of the bed.
b) The LED would flicker some times as it moved from On to Off sensing. On a 3D printer I thing this could cause a problem because when Homing the head touches down the goes back up then back down as a double check. If the On/Off flicker is happening during this time false signals could occur, some video abut this flicker:-
