1Order PCBs
Order the PCBs for the daughter boards
2Assemble Robot Stack
Using the 40 pin connector on the Pi Zero, attach the applicable daughter boards in a stack.
3Robot Setup
Setup the master node and at least three robots to act as the Swarm.
4Start
Begin the robot Swarm and use SSH and video streaming to monitor.
Keith Elliott
