CPU stable!
03/28/2018 at 22:39 • 0 commentsAs per the last post I changed the CPU to run at a fixed speed, and here is the output of cpufreq-info now :)
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009 Report errors and bugs to cpufreq@vger.kernel.org, please. analyzing CPU 0: driver: cpufreq-sunxi CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 2.00 ms. hardware limits: 1.20 GHz - 1.20 GHz available frequency steps: 60.0 MHz, 120 MHz, 240 MHz, 312 MHz, 408 MHz, 480 MHz, 504 MHz, 528 MHz, 576 MHz, 600 MHz, 624 MHz, 648 MHz, 672 MHz, 720 MHz, 768 MHz, 816 MHz, 864 MHz, 912 MHz, 960 MHz, 1.01 GHz, 1.06 GHz, 1.10 GHz, 1.15 GHz, 1.20 GHz, 1.25 GHz, 1.30 GHz, 1.34 GHz, 1.44 GHz, 1.54 GHz available cpufreq governors: interactive, conservative, ondemand, powersave, userspace, performance current policy: frequency should be within 1.20 GHz and 1.20 GHz. The governor "performance" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 60.0 MHz:0.00%, 120 MHz:0.00%, 240 MHz:0.00%, 312 MHz:0.00%, 408 MHz:0.00%, 480 MHz:0.00%, 504 MHz:0.00%, 528 MHz:0.00%, 576 MHz:0.00%, 600 MHz:0.00%, 624 MHz:0.00%, 648 MHz:0.00%, 672 MHz:0.00%, 720 MHz:0.00%, 768 MHz:0.00%, 816 MHz:0.00%, 864 MHz:0.00%, 912 MHz:0.00%, 960 MHz:0.00%, 1.01 GHz:0.00%, 1.06 GHz:0.00%, 1.10 GHz:0.00%, 1.15 GHz:0.00%, 1.20 GHz:100.00%, 1.25 GHz:0.00%, 1.30 GHz:0.00%, 1.34 GHz:0.00%, 1.44 GHz:0.00%, 1.54 GHz:0.00% (1) analyzing CPU 1: driver: cpufreq-sunxi CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 2.00 ms. hardware limits: 1.20 GHz - 1.20 GHz available frequency steps: 60.0 MHz, 120 MHz, 240 MHz, 312 MHz, 408 MHz, 480 MHz, 504 MHz, 528 MHz, 576 MHz, 600 MHz, 624 MHz, 648 MHz, 672 MHz, 720 MHz, 768 MHz, 816 MHz, 864 MHz, 912 MHz, 960 MHz, 1.01 GHz, 1.06 GHz, 1.10 GHz, 1.15 GHz, 1.20 GHz, 1.25 GHz, 1.30 GHz, 1.34 GHz, 1.44 GHz, 1.54 GHz available cpufreq governors: interactive, conservative, ondemand, powersave, userspace, performance current policy: frequency should be within 1.20 GHz and 1.20 GHz. The governor "performance" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 60.0 MHz:0.00%, 120 MHz:0.00%, 240 MHz:0.00%, 312 MHz:0.00%, 408 MHz:0.00%, 480 MHz:0.00%, 504 MHz:0.00%, 528 MHz:0.00%, 576 MHz:0.00%, 600 MHz:0.00%, 624 MHz:0.00%, 648 MHz:0.00%, 672 MHz:0.00%, 720 MHz:0.00%, 768 MHz:0.00%, 816 MHz:0.00%, 864 MHz:0.00%, 912 MHz:0.00%, 960 MHz:0.00%, 1.01 GHz:0.00%, 1.06 GHz:0.00%, 1.10 GHz:0.00%, 1.15 GHz:0.00%, 1.20 GHz:100.00%, 1.25 GHz:0.00%, 1.30 GHz:0.00%, 1.34 GHz:0.00%, 1.44 GHz:0.00%, 1.54 GHz:0.00% (1) analyzing CPU 2: driver: cpufreq-sunxi CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 2.00 ms. hardware limits: 1.20 GHz - 1.20 GHz available frequency steps: 60.0 MHz, 120 MHz, 240 MHz, 312 MHz, 408 MHz, 480 MHz, 504 MHz, 528 MHz, 576 MHz, 600 MHz, 624 MHz, 648 MHz, 672 MHz, 720 MHz, 768 MHz, 816 MHz, 864 MHz, 912 MHz, 960 MHz, 1.01 GHz, 1.06 GHz, 1.10 GHz, 1.15 GHz, 1.20 GHz, 1.25 GHz, 1.30 GHz, 1.34 GHz, 1.44 GHz, 1.54 GHz available cpufreq governors: interactive, conservative, ondemand, powersave, userspace, performance current policy: frequency should be within 1.20 GHz and 1.20 GHz. The governor "performance" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 60.0 MHz:0.00%, 120 MHz:0.00%, 240 MHz:0.00%, 312 MHz:0.00%, 408 MHz:0.00%, 480 MHz:0.00%, 504 MHz:0.00%, 528 MHz:0.00%, 576 MHz:0.00%, 600 MHz:0.00%, 624 MHz:0.00%, 648 MHz:0.00%, 672 MHz:0.00%, 720 MHz:0.00%, 768 MHz:0.00%, 816 MHz:0.00%, 864 MHz:0.00%, 912 MHz:0.00%, 960 MHz:0.00%, 1.01 GHz:0.00%, 1.06 GHz:0.00%, 1.10 GHz:0.00%, 1.15 GHz:0.00%, 1.20 GHz:100.00%, 1.25 GHz:0.00%, 1.30 GHz:0.00%, 1.34 GHz:0.00%, 1.44 GHz:0.00%, 1.54 GHz:0.00% (1) analyzing CPU 3: driver: cpufreq-sunxi CPUs which run at the same hardware frequency: 0 1 2 3 CPUs which need to have their frequency coordinated by software: 0 1 2 3 maximum transition latency: 2.00 ms. hardware limits: 1.20 GHz - 1.20 GHz available frequency steps: 60.0 MHz, 120 MHz, 240 MHz, 312 MHz, 408 MHz, 480 MHz, 504 MHz, 528 MHz, 576 MHz, 600 MHz, 624 MHz, 648 MHz, 672 MHz, 720 MHz, 768 MHz, 816 MHz, 864 MHz, 912 MHz, 960 MHz, 1.01 GHz, 1.06 GHz, 1.10 GHz, 1.15 GHz, 1.20 GHz, 1.25 GHz, 1.30 GHz, 1.34 GHz, 1.44 GHz, 1.54 GHz available cpufreq governors: interactive, conservative, ondemand, powersave, userspace, performance current policy: frequency should be within 1.20 GHz and 1.20 GHz. The governor "performance" may decide which speed to use within this range. current CPU frequency is 1.20 GHz (asserted by call to hardware). cpufreq stats: 60.0 MHz:0.00%, 120 MHz:0.00%, 240 MHz:0.00%, 312 MHz:0.00%, 408 MHz:0.00%, 480 MHz:0.00%, 504 MHz:0.00%, 528 MHz:0.00%, 576 MHz:0.00%, 600 MHz:0.00%, 624 MHz:0.00%, 648 MHz:0.00%, 672 MHz:0.00%, 720 MHz:0.00%, 768 MHz:0.00%, 816 MHz:0.00%, 864 MHz:0.00%, 912 MHz:0.00%, 960 MHz:0.00%, 1.01 GHz:0.00%, 1.06 GHz:0.00%, 1.10 GHz:0.00%, 1.15 GHz:0.00%, 1.20 GHz:100.00%, 1.25 GHz:0.00%, 1.30 GHz:0.00%, 1.34 GHz:0.00%, 1.44 GHz:0.00%, 1.54 GHz:0.00% (1)
Asic Errors, USB Woes, and !winning!
03/28/2018 at 16:09 • 0 commentsI think the next thing I'm going to work on will be SPI / netboot
I'm going to start with a newly compiled uboot on the SD card to get netbooting working, then I will transfer that working uboot to the SPI flash, cant wait to be done flashing and reading sd cards all day.
The results of that are this correctly configured fex though (opi one), use fex2bin and replace /boot/script.bin
this gets rid of the asic CPU set errors, but it also sets the CPU to a constant speed (which is ok with me), and fixes USB issues
--------------UPDATE-----------------
I was just told that the site malformed this file, DO NOT COPY/PASTE THIS
I will post the file in the files section
[product] version = "100" machine = "Xunlong Orange Pi One" [platform] debug_mode = 1 eraseflag = 1 next_work = 2 [target] boot_clock = 1008 storage_type = -1 [key_detect_en] keyen_flag = 0 [fel_key] fel_key_max = 7 fel_key_min = 2 [card_boot] logical_start = 40960 sprite_work_delay = 500 sprite_err_delay = 200 sprite_gpio0 = port:PL10<1><default><default><default> next_work = 3 [box_start_os] used = 1 start_type = 1 irkey_used = 1 pmukey_used = 1 pmukey_num = 3 led_power = 0 led_state = 0 [boot_init_gpio] used = 1 gpio0 = port:PL10<1><default><default><1> gpio1 = port:PG11<1><default><default><1> [recovery_para] used = 1 mode = 2 recovery_key = port:PL04<0><default><default><default> [pm_para] standby_mode = 1 [card0_boot_para] card_ctrl = 0 card_high_speed = 1 card_line = 4 sdc_d1 = port:PF00<2><1><2><default> sdc_d0 = port:PF01<2><1><2><default> sdc_clk = port:PF02<2><1><2><default> sdc_cmd = port:PF03<2><1><2><default> sdc_d3 = port:PF04<2><1><2><default> sdc_d2 = port:PF05<2><1><2><default> [card2_boot_para] card_ctrl = 2 card_high_speed = 1 card_line = 8 sdc_cmd = port:PC06<3><1><2><default> sdc_clk = port:PC05<3><1><2><default> sdc_d0 = port:PC08<3><1><2><default> sdc_d1 = port:PC09<3><1><2><default> sdc_d2 = port:PC10<3><1><2><default> sdc_d3 = port:PC11<3><1><2><default> sdc_d4 = port:PC12<3><1><2><default> sdc_d5 = port:PC13<3><1><2><default> sdc_d6 = port:PC14<3><1><2><default> sdc_d7 = port:PC15<3><1><2><default> sdc_2xmode = 1 sdc_ddrmode = 1 [twi_para] twi_port = 0 twi_scl = port:PA11<2><default><default><default> twi_sda = port:PA12<2><default><default><default> [uart_para] uart_debug_port = 0 uart_debug_tx = port:PA04<2><1><default><default> uart_debug_rx = port:PA05<2><1><default><default> [force_uart_para] force_uart_port = 0 force_uart_tx = port:PF02<3><1><default><default> force_uart_rx = port:PF04<3><1><default><default> [jtag_para] jtag_enable = 0 jtag_ms = port:PA00<3><default><default><default> jtag_ck = port:PA01<3><default><default><default> jtag_do = port:PA02<3><default><default><default> jtag_di = port:PA03<3><default><default><default> [clock] pll_video = 297 pll_ve = 402 pll_periph0 = 600 pll_gpu = 576 pll_periph1 = 600 pll_de = 864 [dram_para] dram_clk = 624 dram_type = 3 dram_zq = 0x3b3bfb dram_odt_en = 1 dram_para1 = 283377664 dram_para2 = 0 dram_mr0 = 6208 dram_mr1 = 64 dram_mr2 = 24 dram_mr3 = 2 dram_tpr0 = 0x48a192 dram_tpr1 = 0x1c2418d dram_tpr2 = 0x76051 dram_tpr3 = 0x0 dram_tpr4 = 0x0 dram_tpr5 = 0x0 dram_tpr6 = 0x64 dram_tpr7 = 0x0 dram_tpr8 = 0x0 dram_tpr9 = 0x0 dram_tpr10 = 0x0 dram_tpr11 = 0x6aaa0000 dram_tpr12 = 0x7979 dram_tpr13 = 0x800800 [wakeup_src_para] cpu_en = 0 cpu_freq = 48 pll_ratio = 273 dram_selfresh_en = 1 dram_freq = 36 wakeup_src0 = wakeup_src_wl = port:PG10<4><default><default><0> wakeup_src_bt = port:PL03<6><default><default><0> [twi0] twi_used = 1 twi_scl = port:PA11<2><default><default><default> twi_sda = port:PA12<2><default><default><default> [twi1] twi_used = 1 twi_scl = port:PA18<3><default><default><default> twi_sda = port:PA19<3><default><default><default> [twi2] twi_used = 0 twi_scl = port:PE12<3><default><default><default> twi_sda = port:PE13<3><default><default><default> [uart0] uart_used = 1 uart_port = 0 uart_type = 2 uart_tx = port:PA04<2><1><default><default> uart_rx = port:PA05<2><1><default><default> [uart1] uart_used = 0 uart_port = 1 uart_type = 4 uart_tx = port:PG06<2><1><default><default> uart_rx = port:PG07<2><1><default><default> uart_rts = port:PG08<2><1><default><default> uart_cts = port:PG09<2><1><default><default> [uart2] uart_used = 0 uart_port = 2 uart_type = 4 uart_tx = port:PA00<2><1><default><default> uart_rx = port:PA01<2><1><default><default> uart_rts = port:PA02<2><1><default><default> uart_cts = port:PA03<2><1><default><default> [uart3] uart_used = 0 uart_port = 3 uart_type = 4 uart_tx = port:PA13<3><1><default><default> uart_rx = port:PA14<3><1><default><default> uart_rts = port:PA15<3><1><default><default> uart_cts = port:PA16<3><1><default><default> [spi0] spi_used = 1 spi_cs_bitmap = 1 spi_mosi = port:PC00<3><default><default><default> spi_miso = port:PC01<3><default><default><default> spi_sclk = port:PC02<3><default><default><default> spi_cs0 = port:PC03<3><1><default><default> [spi1] spi_used = 0 spi_cs_bitmap = 1 spi_cs0 = port:PA13<2><1><default><default> spi_sclk = port:PA14<2><default><default><default> spi_mosi = port:PA15<2><default><default><default> spi_miso = port:PA16<2><default><default><default> [spi_devices] spi_dev_num = 1 [spi_board0] modalias = "spidev" max_speed_hz = 33000000 bus_num = 0 chip_select = 0 mode = 0 full_duplex = 1 manual_cs = 0 [gpio_para] gpio_used = 0 gpio_num = 0 [leds_para] leds_used = 1 green_led = port:PL10<1><default><default><1> green_led_active_low = 0 red_led = port:PA15<1><default><default><0> red_led_active_low = 0 [ths_para] ths_used = 1 ths_trip1_count = 6 ths_trip1_0 = 75 ths_trip1_1 = 80 ths_trip1_2 = 85 ths_trip1_3 = 90 ths_trip1_4 = 95 ths_trip1_5 = 105 ths_trip1_6 = 0 ths_trip1_7 = 0 ths_trip1_0_min = 0 ths_trip1_0_max = 1 ths_trip1_1_min = 1 ths_trip1_1_max = 2 ths_trip1_2_min = 2 ths_trip1_2_max = 3 ths_trip1_3_min = 3 ths_trip1_3_max = 4 ths_trip1_4_min = 4 ths_trip1_4_max = 8 ths_trip1_5_min = 8 ths_trip1_5_max = 8 ths_trip1_6_min = 0 ths_trip1_6_max = 0 ths_trip2_count = 1 ths_trip2_0 = 105 [cooler_table] cooler_count = 1 cooler0 = "1200000 4 4294967295 0" [nand0_para] nand_support_2ch = 0 nand0_used = 0 nand0_we = port:PC00<2><default><default><default> nand0_ale = port:PC01<2><default><default><default> nand0_cle = port:PC02<2><default><default><default> nand0_ce1 = port:PC03<2><default><default><default> nand0_ce0 = port:PC04<2><default><default><default> nand0_nre = port:PC05<2><default><default><default> nand0_rb0 = port:PC06<2><default><default><default> nand0_rb1 = port:PC07<2><default><default><default> nand0_d0 = port:PC08<2><default><default><default> nand0_d1 = port:PC09<2><default><default><default> nand0_d2 = port:PC10<2><default><default><default> nand0_d3 = port:PC11<2><default><default><default> nand0_d4 = port:PC12<2><default><default><default> nand0_d5 = port:PC13<2><default><default><default> nand0_d6 = port:PC14<2><default><default><default> nand0_d7 = port:PC15<2><default><default><default> nand0_ndqs = port:PC16<2><default><default><default> [boot_disp] advert_disp = 0 auto_hpd = 1 output_type = 4 hdmi_channel = 0 hdmi_mode = 4 cvbs_channel = 1 cvbs_mode = 11 output_full = 1 hdmi_mode_check = 1 [disp_init] disp_init_enable = 1 disp_mode = 0 screen0_output_type = 3 screen0_output_mode = 5 screen1_output_type = 3 screen1_output_mode = 5 fb0_format = 0 fb0_width = 0 fb0_height = 0 fb1_format = 0 fb1_width = 0 fb1_height = 0 [hdmi_para] hdmi_used = 1 hdmi_power = "vcc-hdmi-18" [tv_para] tv_used = 1 tv_dac_used = 1 tv_dac_src0 = 0 [pwm0_para] pwm_used = 0 pwm_positive = port:PA05<3><0><default><default> [gmac0] gmac_used = 2 gmac_power1 = [csi0] vip_used = 1 vip_mode = 0 vip_dev_qty = 1 vip_define_sensor_list = 0 vip_csi_pck = port:PE00<2><default><default><default> vip_csi_mck = port:PE01<2><default><default><default> vip_csi_hsync = port:PE02<2><default><default><default> vip_csi_vsync = port:PE03<2><default><default><default> vip_csi_d0 = port:PE04<2><default><default><default> vip_csi_d1 = port:PE05<2><default><default><default> vip_csi_d2 = port:PE06<2><default><default><default> vip_csi_d3 = port:PE07<2><default><default><default> vip_csi_d4 = port:PE08<2><default><default><default> vip_csi_d5 = port:PE09<2><default><default><default> vip_csi_d6 = port:PE10<2><default><default><default> vip_csi_d7 = port:PE11<2><default><default><default> vip_csi_sck = port:PE12<2><default><default><default> vip_csi_sda = port:PE13<2><default><default><default> vip_dev0_mname = "gc2035" vip_dev0_pos = "front" vip_dev0_lane = 1 vip_dev0_twi_id = 2 vip_dev0_twi_addr = 120 vip_dev0_isp_used = 0 vip_dev0_fmt = 0 vip_dev0_stby_mode = 0 vip_dev0_vflip = 1 vip_dev0_hflip = 1 vip_dev0_iovdd = "" vip_dev0_iovdd_vol = 2800000 vip_dev0_avdd = "" vip_dev0_avdd_vol = 2800000 vip_dev0_dvdd = "" vip_dev0_dvdd_vol = 1800000 vip_dev0_afvdd = "" vip_dev0_afvdd_vol = 2800000 vip_dev0_power_en = port:PA17<1><default><default><1> vip_dev0_reset = port:PE14<1><default><default><1> vip_dev0_pwdn = port:PE15<1><default><default><0> vip_dev0_flash_en = vip_dev0_flash_mode = vip_dev0_af_pwdn = vip_dev0_act_used = 0 vip_dev0_act_name = "ad5820_act" vip_dev0_act_slave = 24 vip_dev1_mname = "" vip_dev1_pos = "rear" vip_dev1_lane = 1 vip_dev1_twi_id = 0 vip_dev1_twi_addr = vip_dev1_isp_used = 0 vip_dev1_fmt = 1 vip_dev1_stby_mode = 0 vip_dev1_vflip = 0 vip_dev1_hflip = 0 vip_dev1_iovdd = "" vip_dev1_iovdd_vol = 2800000 vip_dev1_avdd = "" vip_dev1_avdd_vol = 2800000 vip_dev1_dvdd = "" vip_dev1_dvdd_vol = 1500000 vip_dev1_afvdd = "" vip_dev1_afvdd_vol = 2800000 vip_dev1_power_en = vip_dev1_reset = vip_dev1_pwdn = vip_dev1_flash_en = vip_dev1_flash_mode = vip_dev1_af_pwdn = [tvout_para] tvout_used = 0 tvout_channel_num = tv_en = 0 [tvin_para] tvin_used = 0 tvin_channel_num = [di_para] di_used = 1 [mmc0_para] sdc_used = 1 sdc_detmode = 3 sdc_buswidth = 4 sdc_clk = port:PF02<2><1><2><default> sdc_cmd = port:PF03<2><1><2><default> sdc_d0 = port:PF01<2><1><2><default> sdc_d1 = port:PF00<2><1><2><default> sdc_d2 = port:PF05<2><1><2><default> sdc_d3 = port:PF04<2><1><2><default> sdc_det = port:PF06<0><1><2><default> sdc_use_wp = 0 sdc_wp = sdc_isio = 0 sdc_regulator = "none" sdc_power_supply = "none" [mmc1_para] sdc_used = 1 sdc_detmode = 4 sdc_buswidth = 4 sdc_clk = port:PG00<2><1><3><default> sdc_cmd = port:PG01<2><1><3><default> sdc_d0 = port:PG02<2><1><3><default> sdc_d1 = port:PG03<2><1><3><default> sdc_d2 = port:PG04<2><1><3><default> sdc_d3 = port:PG05<2><1><3><default> sdc_det = sdc_use_wp = 0 sdc_wp = sdc_isio = 1 sdc_regulator = "none" sdc_power_supply = "none" sdc_2xmode = 1 sdc_ddrmode = 1 [mmc2_para] sdc_used = 0 sdc_detmode = 3 sdc_buswidth = 8 sdc_clk = port:PC05<3><1><2><default> sdc_cmd = port:PC06<3><1><2><default> sdc_d0 = port:PC08<3><1><2><default> sdc_d1 = port:PC09<3><1><2><default> sdc_d2 = port:PC10<3><1><2><default> sdc_d3 = port:PC11<3><1><2><default> sdc_d4 = port:PC12<3><1><2><default> sdc_d5 = port:PC13<3><1><2><default> sdc_d6 = port:PC14<3><1><2><default> sdc_d7 = port:PC15<3><1><2><default> emmc_rst = port:PC16<3><1><2><default> sdc_det = sdc_use_wp = 0 sdc_wp = sdc_isio = 0 sdc_regulator = "none" sdc_power_supply = "none" sdc_2xmode = 1 sdc_ddrmode = 1 [smc_para] smc_used = 0 smc_rst = port:PA09<2><default><default><default> smc_vppen = port:PA20<3><default><default><default> smc_vppp = port:PA21<3><default><default><default> smc_det = port:PA10<2><default><default><default> smc_vccen = port:PA06<2><default><default><default> smc_sck = port:PA07<2><default><default><default> smc_sda = port:PA08<2><default><default><default> [usbc0] usb_used = 1 usb_port_type = 2 usb_detect_type = 0 usb_id_gpio = port:PG12<0><1><default><default> usb_det_vbus_gpio = port:PG12<0><1><default><default> usb_drv_vbus_gpio = port:PL02<1><0><default><0> usb_host_init_state = 1 usb_restrict_gpio = usb_restric_flag = 0 usb_restric_voltage = 3550000 usb_restric_capacity = 5 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 [usbc1] usb_used = 1 usb_drv_vbus_gpio = usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 [usbc2] usb_used = 1 usb_drv_vbus_gpio = usb_restrict_gpio = usb_host_init_state = 1 usb_restric_flag = 0 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 [usbc3] usb_used = 1 usb_drv_vbus_gpio = usb_restrict_gpio = usb_host_init_state = 0 usb_restric_flag = 0 usb_regulator_io = "nocare" usb_regulator_vol = 0 usb_not_suspend = 0 [usb_feature] vendor_id = 6353 mass_storage_id = 1 adb_id = 2 manufacturer_name = "USB Developer" product_name = "Android" serial_number = "20080411" [msc_feature] vendor_name = "USB 2.0" product_name = "USB Flash Driver" release = 100 luns = 3 [serial_feature] serial_unique = 0 [module_para] module_num = 7 module_power0 = "vcc-wifi-33" module_power0_vol = 0 module_power1 = module_power1_vol = module_power2 = module_power2_vol = module_power3 = module_power3_vol = chip_en = lpo_use_apclk = [wifi_para] wifi_used = 1 wifi_sdc_id = 1 wifi_usbc_id = 2 wifi_usbc_type = 1 wl_reg_on = port:PL07<1><default><default><0> wl_host_wake = port:PG10<0><default><default><0> wl_host_wake_invert = 0 [bt_para] bt_used = 0 bt_
I need a beer (or 6)
03/27/2018 at 06:54 • 0 commentsSo, after bashing my head against the wall for a long time I finally got the camera working, I had to start with a 5.20 image because hte fex in later build is wrong.....
Ill be posting the image later, it will save you much much trouble....
Soup is done!
03/27/2018 at 00:21 • 0 commentsThat's a lie.
I came back and realized I didnt add linux-headers-sun8i to my first apt-get, as they are not installed by default.
Edit:
4 hours later, still futzing to get it to load the drivers and detect the CSI camera.......
Sigh
Lunch time
03/26/2018 at 19:23 • 0 commentsThe first few packages, ran this in a file named step1.sh:
sudo apt-get update -y sudo apt-get upgrade -y sudo apt-get install python-dev python-pip python-opencv libv4l-dev -y git clone https://github.com/umlaeute/v4l2loopback cd v4l2loopback/ make && make install cd .. git clone https://github.com/lhelontra/vidcopy cd vidcopy/ gcc vidcopy.c -o vidcopy cd .. echo "v4l2loopback" | sudo tee -a /etc/modules echo "gc2035" | sudo tee -a /etc/modules echo "vfe_v4l2" | sudo tee -a /etc/modules
That will take a while, time for lunch and to start the the next project!
Let there be sound?
03/26/2018 at 18:45 • 0 comments
root@orangepione:~# speaker-test speaker-test 1.0.28 Playback device is default Stream parameters are 48000Hz, S16_LE, 1 channels Using 16 octaves of pink noise Rate set to 48000Hz (requested 48000Hz) Buffer size range from 256 to 524288 Period size range from 128 to 65536 Using max buffer size 524288 Periods = 4 was set period_size = 65536 was set buffer_size = 524288 0 - Front LeftOops, looks like I flipped the speakers though!
Armbian, and the need for speed
03/26/2018 at 18:32 • 0 commentsFirst thing was first, I had done some research on reading temp sensors and they fail at 408mhz, which is the "slow" speed, this board doesn't have a proper voltage selectable voltage regulator, just a VR that is settable via resistors, and that's 1.2ghz or 408mhz
sudo nano /etc/default/cpufrequtils
ENABLE=true MIN_SPEED=1200000 MAX_SPEED=1200000 GOVERNOR=performance
sudo watch -n 1 cat /sys/devices/system/cpu/cpu*/cpufreq/cpuinfo_cur_freq
Every 1.0s: cat /sys/devices/system/cpu/cpu0/cpufre... Mon Mar 26 20:31:38 2018 1200000 1200000 1200000 1200000
Much better :)
WHY?!?
03/26/2018 at 17:47 • 0 commentsWhy is it that yesterday, when I didn't need them, I came across at least 3 usb > 3.3v serial adapters... now that I need ONE to debug this I cant find any.....
Prop plug to the rescue!U-Boot 2017.09-armbian (Nov 22 2017 - 16:47:31 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Net: phy interface0 eth0: ethernet@1c30000 230454 bytes read in 195 ms (1.1 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press to stop => U-Boot SPL 2017.09-armbian (Nov 22 2017 - 16:47:31) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2017.09-armbian (Nov 22 2017 - 16:47:31 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB ▒ U-Boot SPL 2017.09-armbian (Nov 22 2017 - 16:47:31) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2017.09-armbian (Nov 22 2017 - 16:47:31 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Net: phy interface0 eth0: ethernet@1c30000 230454 bytes read in 194 ms (1.1 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press to stop switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found U-Boot script /boot/boot.scr 3708 bytes read in 198 ms (17.6 KiB/s) ## Executing script at 43100000 U-boot loaded from SD Boot script loaded from mmc 115 bytes read in 150 ms (0 Bytes/s) 3812646 bytes read in 447 ms (8.1 MiB/s) 4751880 bytes read in 509 ms (8.9 MiB/s) Found legacy kernel configuration 34704 bytes read in 494 ms (68.4 KiB/s) ## Loading init Ramdisk from Legacy Image at 43300000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3812582 Bytes = 3.6 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK Starting kernel ... [sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 512MB ion_carveout reserve: 160m@0 256m@0 130m@1 200m@1 ion_reserve_select: ion chipid [0x2c00081! ion_reserve_common: ion reserve: [0x56000000, 0x60000000]! Loading, please wait... Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Will now check root file system ... fsck from util-linux 2.25.2 [/sbin/fsck.ext4 (1) -- /dev/mmcblk0p1] fsck.ext4 -a -C0 /dev/mmcblk0p1 /dev/mmcblk0p1: clean, 34994/72720 files, 199522/290816 blocks done. done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... done. Welcome to Debian GNU/Linux 8 (jessie)! Expecting device dev-ttyS0.device... [ OK ] Reached target Remote File Systems (Pre). [ OK ] Reached target Encrypted Volumes. [ OK ] Reached target Paths. [ OK ] Set up automount Arbitrary Executable File Formats F...utomount Point. [ OK ] Reached target Swap. [ OK ] Created slice Root Slice. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on Delayed Shutdown Socket. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Created slice User and Session Slice. [ OK ] Listening on udev Control Socket. [ OK ] Listening on udev Kernel Socket. [ OK ] Listening on Journal Socket. [ OK ] Created slice System Slice. Starting Increase datagram queue length... Starting Restore / save the current clock... Starting Nameserver information manager... Mounting POSIX Message Queue File System... Mounting Debug File System... Starting udev Coldplug all Devices... Starting Create list of required static device nodes...rrent kernel... [ OK ] Created slice system-serial\x2dgetty.slice. Starting Load Kernel Modules... ▒[ OK ] Reached target Slices. [ OK ] Mounted Debug File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Started Increase datagram queue length. [ OK ] Started Restore / save the current clock. ▒[ OK ] Started Create list of required static device nodes ...current kernel. [ OK ] Started Load Kernel Modules. [ OK ] Started Nameserver information manager. [ OK ] Started udev Coldplug all Devices. Starting Apply Kernel Variables... Mounting FUSE Control File System... Starting Create Static Device Nodes in /dev... [ OK ] Listening on Syslog Socket. [ OK ] Mounted FUSE Control File System. ▒[ OK ] Started Apply Kernel Variables. [ OK ] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... ▒[ OK ] Started udev Kernel Device Manager. Starting Copy rules generated while the root was ro... Starting LSB: Tune IDE hard disks... Starting LSB: Set preliminary keymap... [ OK ] Started Copy rules generated while the root was ro. U-Boot SPL 2017.09-armbian (Nov 22 2017 - 16:47:31) DRAM: 512 MiB Trying to boot from MMC1 U-Boot 2017.09-armbian (Nov 22 2017 - 16:47:31 +0100) Allwinner Technology CPU: Allwinner H3 (SUN8I 1680) Model: Xunlong Orange Pi One DRAM: 512 MiB MMC: SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: vidconsole Err: vidconsole Net: phy interface0 eth0: ethernet@1c30000 230454 bytes read in 194 ms (1.1 MiB/s) starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 2 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press to stop =>
Well, that took about 10 seconds to discover the power supply I had for it was sagging to 4,4v during boot and the SBC reset.... 1 new power supply later and.....
Debian GNU/Linux 8 orangepione ttyS0 orangepione login:
Thank you baby jesus
Not that easy, OFC
03/26/2018 at 17:43 • 0 commentsSo as expected, NOT that easy, its boot looping, mashing space bar got the boot to stop
-------ALSO-------
An annoyance with documentation, taking pictures of stuff stuff when its dirty, I'm going to be forced to clean everything during this....
OS Image
03/26/2018 at 17:04 • 0 commentsOk, im going to start with this image and then explore more from there.....
https://dl.armbian.com/orangepione/Debian_jessie_default.7z.torrent
Should be easy... Right?
