The hilt is a Darth Vader based design with some personal changes. it was 3d printed and then painted. The light source is a simple led torch with a variable light angle. The tip was machined out of perspecs and the blade is a perspects tube. I can change the light source color by using different color lenses that go between the torch and blade.
