1Step 1
Get your PCB first, but you can also using DIP style ATTiny and using your bread board and follow the connection from schematic above.
If you have access to making a PCB this is the Gerber files or you can also using SOIC-break-out-board -
2Step 2
Solder the chip according to this list of pin usages :
PB0 : RX/TX purposesPB1 : SERVO A / SERVO 1
PB2 : SERVO B / SERVO 2
PB3 : SERVO C / SERVO 3
PB4 : SERVO D / SERVO 4
PB5 : SERVO E / SERVO 5 or RESET pin (disable from fuse bit to enable this channel but you can't program the chip with standard ISP programmer)
3Step 3
Burn the chip with this hex file and set the fuse bit to High 0xFF Low 0x7A (reset enable) or High 0xFE Low 0x7A (reset disable).
arief ibrahim adha
