As blinkinaday noted, there is a second, different waterfall image from the wayback machine, that can be accessed here:
https://web.archive.org/web/20150911223837/https://infotomb.com/uy6vy.png
This project log is about deciphering the stego and FEZ code of this image (boring). You can skip it entirely and just download the results if you wish:
https://cdn.hackaday.io/files/8762374873408/Waterfall_Wayback.zip
Ok, here we go, this is the image. It looks like the image on the itanimulli page, but, if you look closely (very closely..), there are yet some differences:
I will now quickly deconstruct this without getting into too much details:
LSB stego
RGB
Red
Green
Blue
Ok, next step is deciphering that stuff.
FEZ code
Red
G ,S ,O ,S ,R ,KQ,P ,B ,G ,F ,KQ,KQ,Y ,F ,T ,A ,A ,A ,A ,A ,A ,A ,A ,A ,A ,A ,A , L ,D ,UV,P ,UV,A ,G ,J ,P ,E ,X ,N ,R ,E ,KQ,N ,N ,N ,N ,N ,N ,N ,R ,S ,N ,N ,KQ, C ,S ,M ,KQ,W ,KQ,I ,I ,M ,I ,UV,J ,T ,W ,T ,O ,O ,O ,O ,O ,O ,O ,E ,O ,O ,O ,O , KQ,KQ,J ,T ,H ,L ,L ,UV,KQ,S ,P ,P ,S ,T ,T ,UV,UV,UV,UV,UV,UV,UV,P ,L ,UV,UV,A , C ,J ,L ,B ,E ,UV,R ,UV,Y ,J ,I ,B ,N ,A ,F ,I ,I ,I ,I ,I ,I ,I ,L ,UV,I ,I ,N , R ,A ,UV,I ,H ,R ,Y ,KQ,UV,G ,UV,P ,KQ,KQ,M ,C ,C ,C ,C ,C ,C ,C ,Y ,T ,C ,C ,Z , UV,X ,C ,L ,E ,J ,R ,UV,J ,UV,F ,M ,KQ,S ,H ,E ,E ,E ,E ,E ,E ,E ,F ,I ,E ,E ,C , P ,N ,R ,Z ,T ,C ,Y ,Y ,R ,G ,M ,F ,KQ,Y ,F ,W ,S ,S ,S ,S ,S ,S ,R ,O ,A ,C ,S , Z ,P ,O ,Y ,UV,W ,I ,D ,H ,T ,I ,G ,I ,I ,P ,A ,H ,H ,H ,H ,H ,H ,O ,N ,S ,A ,X , F ,T ,N ,KQ,I ,C ,W ,G ,D ,UV,G ,A ,UV,C ,Y ,S ,O ,O ,O ,O ,O ,O ,M ,T ,KQ,M ,A , KQ,D ,E ,L ,I ,L ,Y ,O ,D ,X ,G ,H ,F ,KQ,N ,E ,UV,UV,UV,UV,UV,UV,A ,O ,E ,E ,F , UV,L ,R ,B ,B ,L ,O ,UV,G ,M ,UV,G ,P ,G ,R ,N ,L ,L ,L ,L ,L ,L ,M ,R ,D ,T ,KQ, S ,T ,O ,O ,I ,A ,F ,UV,B ,A ,F ,UV,J ,P ,KQ,L ,D ,D ,D ,D ,D ,D ,A ,I ,H ,O ,P , W ,M ,L ,J ,KQ,F ,UV,R ,A ,P ,S ,W ,KQ,Y ,L ,I ,S ,S ,S ,S ,S ,S ,S ,D ,O ,A ,R , G ,O ,UV,M ,D ,G ,N ,M ,H ,D ,A ,UV,F ,Y ,UV,G ,O ,E ,O ,E ,O ,E ,T ,D ,W ,M ,D , E ,B ,L ,O ,UV,E ,I ,A ,UV,C ,M ,H ,G ,B ,G ,H ,F ,A ,F ,A ,F ,A ,E ,L ,T ,A ,A , KQ,UV,O ,A ,A ,D ,C ,Z ,H ,X ,B ,P ,H ,E ,W ,T ,I ,R ,I ,R ,I ,R ,R ,E ,O ,S ,H , UV,Z ,H ,A ,J ,F ,E ,UV,Z ,L ,F ,UV,W ,T ,E ,E ,N ,C ,N ,C ,N ,C ,W ,S ,F ,T ,Y , C ,M ,E ,C ,L ,A ,M ,UV,C ,R ,W ,P ,D ,Z ,E ,N ,D ,H ,D ,H ,D ,H ,A ,H ,I ,E ,D , UV,H ,M ,M ,UV,J ,X ,B ,I ,KQ,D ,O ,T ,A ,N ,E ,T ,T ,T ,T ,A ,T ,S ,A ,N ,R ,UV, H ,H ,L ,UV,T ,Z ,I ,J ,R ,E ,KQ,A ,J ,F ,E ,D ,H ,H ,H ,H ,B ,H ,Z ,R ,D ,Z ,F , X ,S ,S ,N ,N ,N ,F ,G ,M ,Y ,C ,D ,UV,I ,B ,Z ,E ,R ,E ,R ,O ,R ,G ,D ,Z ,UV,C , D ,W ,KQ,S ,E ,E ,H ,UV,J ,Z ,F ,UV,UV,UV,L ,H ,R ,O ,S ,O ,UV,O ,T ,Z ,Z ,T ,I , A ,B ,E ,F ,N ,Y ,Z ,X ,G ,W ,C ,E ,I ,P ,N ,C ,I ,UV,KQ,UV,L ,UV,R ,J ,M ,J ,UV, C ,P ,X ,J ,R ,A ,R ,X ,KQ,X ,J ,Z ,UV,B ,UV,N ,UV,G ,Y ,G ,D ,G ,H ,A ,I ,O ,G , UV,M ,Z ,J ,E ,Y ,W ,D ,B ,H ,H ,O ,S ,B ,C ,Y ,E ,H ,Z ,H ,E ,H ,Z ,E ,O ,N ,B , B ,KQ,W ,X ,D ,I ,L ,L ,UV,H ,I ,B ,Z ,T ,UV,A ,R ,W ,I ,A ,R ,S ,W ,UV,G ,KQ,G , C ,M ,M ,S ,T ,I ,G ,KQ,I ,Z ,I ,M ,UV,J ,KQ,L ,Z ,A ,I ,I ,Z ,A ,A ,B ,D ,J ,B , O ,X ,W ,F ,A ,UV,P ,T ,KQ,KQ,A ,I ,G ,C ,Z ,L ,F ,T ,UV,R ,M ,N ,I ,D ,T ,M ,R , T ,H ,KQ,G ,Z ,O ,P ,N ,M ,P ,KQ,P ,UV,T ,Z ,B ,R ,E ,KQ,Z ,A ,D ,E ,T ,UV,M ,N , Z ,S ,C ,D ,KQ,A ,D ,H ,Z ,H ,A ,F ,L ,B ,B ,UV,Y ,R ,C ,E ,H ,Z ,E ,Y ,S ,R ,O , E ,E ,D ,UV,KQ,X ,W ,C ,X ,L ,M ,A ,F ,F ,KQ,R ,KQ,Z ,E ,S ,Y ,N ,W ,P ,KQ,W ,N , E ,I ,I ,B ,O ,M ,O ,Y ,UV,B ,B ,Y ,R ,E ,O ,B ,G ,S ,Z ,O ,F ,S ,KQ,KQ,T ,N ,KQ, W ,KQ,H ,L ,X ,F ,G ,M ,KQ,M ,UV,UV,J ,N ,Y ,G ,C ,F ,B ,J ,UV,Y ,E ,UV,KQ,UV,C , N ,R ,D ,KQ,S ,I ,C ,L ,G ,O ,F ,O ,I ,C ,UV,P ,UV,Y ,T ,R ,L ,F ,J ,KQ,B ,X ,W , C ,Y ,C ,L ,A ,D ,C ,M ,UV,UV,R ,UV,KQ,P ,J ,KQ,UV,H ,T ,R ,H ,B ,A ,O ,T ,J ,S , KQ,KQ,H ,UV,I ,I ,X ,D ,KQ,S ,R ,E ,J ,S ,B ,I ,X ,W ,X ,T ,F ,UV,F ,L ,J ,W ,KQ, I ,W ,R ,F ,T ,N ,R ,T ,L ,C ,D ,R ,B ,J ,UV,Z ,UV,W ,D ,W ,KQ,L ,S ,L ,H ,I ,B , T ,W ,P ,M ,O ,I ,M ,X ,D ,W ,F ,Y ,Y ,L ,G ,T ,D ,C ,L ,S ,O ,B ,UV,F ,E ,Z ,E , H ,Y ,F ,KQ,J ,Y ,Z ,I ,L ,O ,KQ,P ,D ,C ,P ,O ,KQ,G ,F ,KQ,UV,J ,A ,I ,X ,UV,D ,
Green
J ,E ,T ,X ,D ,O ,E ,B ,F ,KQ,S ,O ,Y ,D ,H ,I ,UV,KQ,S ,W ,X ,G ,P ,W ,A ,E ,G , I ,N ,M ,J ,X ,L ,R ,D ,P ,Y ,Y ,Y ,G ,UV,E ,Z ,B ,G ,D ,H ,L ,KQ,KQ,Z ,Z ,S ,N , KQ,P ,M ,J ,R ,X ,KQ,H ,Z ,Y ,F ,W ,E ,E ,L ,P ,E ,UV,R ,T ,G ,M ,P ,N ,H ,KQ,A , D ,M ,Z ,H ,W ,KQ,M ,G ,I ,H ,A ,UV,Z ,C ,J ,C ,F ,O ,KQ,G ,Y ,Z ,G ,M ,Y ,R ,T , M ,KQ,J ,UV,UV,UV,J ,A ,R ,Z ,L ,KQ,UV,G ,KQ,I ,G ,Y ,A ,B ,F ,G ,O ,W ,UV,G ,L , H ,N ,B ,B ,KQ,D ,Y ,E ,Z ,S ,R ,A ,KQ,D ,N ,W ,UV,Y ,O ,J ,I ,O ,G ,O ,D ,T ,N , D ,B ,W ,KQ,X ,B ,H ,X ,N ,UV,A ,A ,O ,F ,H ,O ,B ,O ,O ,R ,I ,A ,H ,N ,M ,W ,UV, UV,T ,E ,Z ,F ,KQ,M ,R ,E ,S ,UV,UV,L ,A ,D ,N ,G ,W ,P ,S ,Y ,D ,O ,L ,X ,G ,W , W ,F ,M ,KQ,Y ,UV,S ,B ,UV,R ,H ,N ,N ,H ,H ,G ,G ,N ,UV,R ,Y ,X ,X ,W ,M ,P ,UV, N ,C ,A ,Y ,Y ,W ,D ,Y ,UV,M ,X ,A ,W ,E ,KQ,D ,S ,N ,W ,Y ,T ,P ,J ,I ,J ,C ,T , T ,A ,W ,UV,A ,E ,D ,UV,D ,B ,R ,KQ,H ,UV,KQ,M ,F ,N ,UV,M ,KQ,Z ,T ,Z ,T ,F ,S , M ,I ,E ,H ,C ,P ,B ,E ,KQ,J ,P ,X ,N ,KQ,O ,Z ,J ,P ,R ,W ,I ,D ,B ,KQ,E ,M ,M , G ,Z ,P ,KQ,F ,D ,KQ,P ,KQ,T ,UV,UV,M ,H ,B ,Z ,S ,A ,O ,T ,A ,W ,Z ,UV,W ,C ,L , H ,R ,P ,KQ,S ,G ,T ,O ,UV,O ,UV,I ,M ,J ,E ,D ,UV,UV,D ,KQ,T ,H ,A ,S ,W ,D ,D , A ,E ,Y ,KQ,W ,UV,S ,R ,A ,KQ,O ,J ,I ,E ,R ,X ,X ,M ,UV,R ,E ,L ,J ,T ,UV,S ,J , X ,A ,I ,B ,C ,X ,L ,Y ,E ,H ,UV,C ,E ,C ,C ,S ,F ,KQ,L ,UV,C ,T ,X ,O ,I ,P ,A , UV,D ,I ,P ,R ,C ,T ,Y ,S ,S ,M ,H ,M ,KQ,I ,UV,Z ,N ,E ,D ,UV,S ,G ,E ,Z ,R ,H , B ,I ,M ,KQ,Z ,Z ,UV,X ,O ,J ,UV,M ,N ,KQ,P ,S ,O ,H ,R ,G ,C ,I ,B ,F ,S ,A ,Y , T ,N ,M ,O ,W ,P ,M ,Z ,D ,R ,W ,C ,R ,UV,M ,Z ,KQ,J ,I ,C ,M ,G ,UV,P ,Y ,KQ,KQ, L ,G ,O ,O ,E ,S ,W ,A ,N ,T ,L ,J ,I ,H ,S ,C ,Z ,N ,M ,J ,R ,KQ,W ,UV,F ,F ,KQ, Z ,T ,KQ,A ,UV,F ,F ,D ,O ,R ,W ,R ,S ,P ,X ,F ,F ,O ,T ,E ,UV,UV,Y ,S ,M ,D ,KQ, T ,H ,Y ,T ,H ,P ,Z ,C ,H ,N ,D ,H ,W ,O ,C ,X ,E ,B ,I ,B ,O ,R ,D ,KQ,UV,H ,UV, H ,I ,D ,Y ,Y ,G ,J ,P ,N ,Z ,E ,E ,A ,O ,KQ,L ,R ,I ,C ,F ,E ,UV,L ,G ,R ,Z ,I , I ,S ,Z ,X ,UV,UV,J ,M ,M ,N ,R ,N ,Z ,P ,L ,KQ,L ,B ,S ,F ,W ,E ,O ,T ,L ,J ,X , S ,T ,D ,J ,E ,P ,G ,H ,J ,G ,J ,E ,R ,S ,J ,I ,E ,UV,R ,L ,S ,I ,C ,O ,W ,C ,UV, I ,E ,W ,A ,B ,I ,X ,X ,N ,H ,H ,O ,I ,H ,KQ,X ,P ,A ,C ,B ,S ,C ,H ,J ,P ,N ,L , S ,X ,Z ,D ,F ,B ,O ,KQ,UV,L ,S ,T ,KQ,H ,J ,E ,I ,R ,M ,D ,R ,C ,O ,R ,N ,KQ,KQ, T ,T ,A ,H ,D ,O ,Z ,M ,KQ,Z ,S ,KQ,S ,UV,X ,KQ,R ,P ,I ,D ,R ,O ,C ,B ,J ,S ,G , H ,J ,P ,P ,H ,O ,E ,H ,E ,M ,C ,B ,S ,Z ,UV,B ,P ,KQ,B ,X ,X ,KQ,F ,M ,E ,B ,F , E ,UV,E ,X ,C ,G ,C ,G ,E ,KQ,F ,KQ,G ,C ,M ,L ,KQ,R ,UV,KQ,R ,E ,D ,O ,B ,Y ,Y , W ,S ,R ,KQ,E ,Y ,UV,D ,S ,G ,G ,X ,T ,S ,Z ,A ,I ,R ,D ,F ,KQ,B ,B ,P ,KQ,X ,D , R ,T ,S ,L ,O ,P ,H ,P ,Y ,N ,L ,UV,UV,R ,W ,J ,W ,P ,N ,B ,N ,B ,E ,O ,I ,S ,B , O ,R ,O ,Z ,F ,L ,Z ,E ,R ,D ,KQ,Y ,D ,E ,KQ,N ,T ,Z ,R ,J ,G ,Y ,F ,L ,I ,Z ,B , N ,I ,N ,Z ,T ,D ,M ,L ,F ,E ,O ,Z ,D ,B ,J ,J ,B ,KQ,O ,T ,R ,D ,N ,UV,L ,B ,UV, G ,G ,A ,A ,C ,H ,N ,X ,KQ,Y ,T ,G ,P ,M ,J ,KQ,P ,S ,A ,G ,F ,X ,M ,G ,W ,F ,A , P ,H ,M ,H ,X ,UV,KQ,L ,UV,J ,O ,J ,N ,J ,H ,T ,P ,E ,B ,L ,T ,T ,E ,L ,UV,M ,UV, L ,T ,A ,A ,W ,N ,N ,B ,KQ,C ,Y ,UV,G ,L ,I ,O ,A ,F ,W ,T ,G ,Z ,H ,KQ,Z ,I ,C , A ,N ,Z ,I ,T ,J ,A ,KQ,D ,L ,R ,T ,W ,B ,W ,R ,UV,A ,I ,UV,R ,H ,F ,G ,Z ,O ,F , C ,O ,E ,KQ,C ,A ,KQ,KQ,M ,O ,N ,E ,UV,D ,KQ,D ,Z ,KQ,J ,M ,KQ,O ,Z ,A ,C ,KQ,B , E ,W ,D ,UV,D ,B ,I ,Z ,L ,J ,E ,Z ,W ,W ,L ,B ,F ,UV,F ,C ,UV,KQ,L ,T ,UV,W ,F ,
Blue
UV,M ,D ,Y ,H ,Y ,KQ,I ,R ,X ,B ,N ,W ,KQ,I ,X ,UV,S ,H ,T ,A ,D ,S ,S ,Y ,X ,N , X ,R ,H ,F ,W ,KQ,T ,P ,S ,O ,C ,A ,KQ,Z ,N ,B ,I ,A ,I ,T ,M ,D ,UV,Z ,A ,M ,B , F ,P ,UV,B ,B ,J ,J ,R ,Z ,Y ,E ,UV,B ,N ,W ,UV,L ,X ,E ,D ,N ,N ,M ,UV,P ,I ,Z , KQ,X ,R ,T ,L ,C ,Y ,Z ,UV,T ,A ,C ,O ,UV,H ,W ,KQ,Y ,Z ,T ,S ,X ,UV,E ,L ,E ,E , Y ,E ,S ,R ,B ,T ,A ,KQ,A ,Z ,T ,KQ,I ,Y ,J ,G ,S ,KQ,D ,Y ,I ,O ,S ,C ,KQ,S ,M , C ,J ,E ,D ,S ,D ,G ,E ,N ,C ,D ,O ,M ,F ,M ,KQ,A ,Y ,X ,L ,D ,B ,J ,F ,F ,X ,M , KQ,Z ,M ,Y ,P ,KQ,N ,UV,Y ,N ,Y ,E ,N ,R ,B ,M ,UV,G ,C ,S ,I ,M ,G ,P ,B ,O ,C , L ,Y ,R ,R ,L ,Z ,O ,L ,F ,M ,X ,P ,M ,KQ,G ,B ,G ,I ,M ,S ,T ,L ,P ,R ,I ,UV,O , I ,R ,I ,T ,D ,X ,X ,Y ,A ,E ,X ,KQ,Z ,T ,D ,T ,A ,Y ,R ,S ,UV,Y ,P ,N ,J ,S ,Z , KQ,C ,H ,E ,H ,W ,E ,G ,UV,H ,G ,I ,KQ,C ,W ,UV,S ,O ,A ,R ,O ,L ,B ,S ,B ,D ,G , L ,N ,P ,Y ,A ,G ,P ,S ,I ,E ,A ,I ,X ,L ,Z ,M ,H ,KQ,P ,N ,KQ,W ,H ,A ,KQ,J ,W , H ,UV,R ,KQ,UV,F ,UV,KQ,KQ,M ,UV,KQ,N ,A ,R ,UV,H ,O ,W ,X ,L ,T ,G ,H ,KQ,W ,T , KQ,N ,D ,M ,O ,Y ,D ,L ,T ,X ,D ,I ,O ,N ,L ,W ,Y ,B ,I ,I ,F ,KQ,A ,O ,D ,J ,P , A ,D ,G ,A ,J ,L ,N ,P ,P ,H ,I ,Y ,J ,L ,R ,T ,F ,R ,H ,J ,C ,N ,X ,Z ,G ,R ,E , D ,O ,I ,O ,S ,D ,P ,R ,UV,M ,O ,UV,R ,UV,S ,H ,S ,T ,C ,R ,N ,B ,KQ,W ,UV,J ,O , Y ,Z ,D ,N ,F ,A ,B ,L ,W ,D ,Z ,UV,C ,KQ,KQ,W ,O ,C ,Z ,X ,S ,T ,R ,R ,C ,N ,B , J ,R ,W ,W ,R ,Y ,D ,Z ,A ,KQ,G ,KQ,X ,S ,R ,Y ,N ,S ,Y ,D ,O ,O ,G ,UV,F ,X ,X , KQ,UV,N ,F ,F ,N ,X ,KQ,KQ,H ,O ,T ,Y ,A ,Y ,C ,S ,UV,M ,M ,KQ,B ,M ,UV,F ,N ,T , F ,S ,H ,P ,R ,B ,J ,C ,E ,Z ,G ,E ,I ,X ,E ,X ,R ,L ,T ,I ,UV,H ,L ,J ,Z ,L ,O , B ,G ,P ,E ,KQ,D ,KQ,P ,UV,A ,S ,UV,T ,P ,W ,X ,S ,O ,Y ,T ,B ,R ,J ,UV,W ,I ,M , Z ,E ,UV,A ,N ,J ,R ,D ,P ,UV,G ,UV,UV,M ,N ,P ,F ,I ,UV,N ,L ,UV,I ,UV,O ,KQ,G , I ,KQ,B ,UV,C ,D ,L ,T ,T ,E ,X ,G ,J ,J ,D ,I ,M ,Y ,N ,E ,S ,H ,H ,R ,N ,T ,A , Z ,S ,H ,P ,E ,KQ,G ,J ,J ,G ,H ,C ,W ,X ,O ,UV,Z ,I ,S ,KQ,M ,W ,N ,N ,N ,KQ,UV, KQ,A ,Z ,P ,M ,UV,F ,UV,Z ,A ,S ,S ,Y ,R ,G ,Y ,I ,T ,I ,N ,L ,O ,P ,UV,H ,A ,UV, T ,Z ,UV,A ,Z ,P ,UV,G ,W ,I ,R ,A ,T ,X ,R ,W ,T ,S ,S ,J ,KQ,R ,O ,N ,H ,E ,J , KQ,W ,X ,Z ,X ,Y ,Y ,L ,G ,S ,A ,O ,P ,H ,Z ,W ,KQ,P ,M ,KQ,UV,Z ,J ,E ,X ,N ,J , B ,T ,L ,J ,I ,E ,S ,L ,T ,F ,G ,I ,I ,N ,KQ,S ,O ,KQ,C ,W ,KQ,N ,I ,Y ,UV,C ,Z , I ,C ,T ,Y ,C ,D ,O ,N ,L ,J ,UV,KQ,F ,D ,H ,Y ,E ,S ,B ,L ,E ,G ,KQ,M ,UV,T ,N , S ,P ,G ,Y ,X ,S ,I ,Z ,D ,R ,O ,R ,F ,N ,F ,T ,M ,O ,KQ,Z ,B ,W ,E ,G ,Y ,N ,W , P ,B ,UV,F ,A ,N ,A ,UV,KQ,Z ,UV,M ,B ,Y ,L ,I ,F ,Z ,UV,P ,N ,R ,F ,Z ,A ,C ,J , UV,J ,R ,P ,N ,F ,Z ,F ,N ,O ,J ,R ,Z ,I ,N ,R ,F ,A ,M ,M ,L ,M ,W ,R ,D ,T ,D , D ,D ,W ,R ,F ,E ,Y ,B ,D ,UV,UV,M ,E ,T ,Y ,T ,UV,N ,Y ,T ,M ,C ,S ,W ,R ,C ,X , KQ,KQ,R ,M ,I ,N ,A ,Z ,X ,KQ,L ,P ,H ,Y ,X ,KQ,G ,H ,M ,KQ,Y ,W ,UV,O ,UV,X ,Z , UV,KQ,C ,G ,M ,F ,N ,KQ,O ,H ,T ,W ,A ,T ,S ,Z ,J ,W ,C ,Y ,M ,H ,X ,Z ,S ,H ,KQ, G ,C ,C ,L ,A ,UV,E ,Z ,S ,H ,UV,UV,Z ,M ,C ,P ,UV,C ,G ,S ,Y ,W ,L ,X ,KQ,KQ,R , H ,E ,E ,E ,Y ,T ,X ,C ,X ,P ,S ,F ,O ,KQ,Y ,T ,B ,T ,I ,H ,X ,A ,O ,S ,H ,R ,I , W ,J ,P ,C ,W ,M ,G ,N ,D ,W ,C ,W ,J ,N ,T ,P ,R ,A ,UV,C ,M ,P ,B ,KQ,C ,W ,G , O ,S ,P ,L ,C ,A ,S ,R ,M ,L ,W ,UV,B ,H ,P ,R ,F ,Z ,E ,Z ,M ,E ,C ,Y ,KQ,UV,UV, D ,Z ,C ,H ,L ,T ,KQ,KQ,O ,O ,W ,UV,L ,D ,J ,KQ,D ,G ,E ,B ,X ,J ,X ,W ,S ,B ,G , Y ,KQ,E ,L ,J ,A ,P ,E ,Y ,A ,R ,A ,Y ,E ,D ,B ,H ,X ,D ,UV,P ,UV,KQ,KQ,T ,W ,W ,
So, what does this mean? Any ideas?
Moritz Walter
Do you remember that the corner "orientation" markers also decode to different values in each of the RGB color channels? Maybe this orientation markers are the "reading shape" of the relevant data we're looking for...
Bear in mind that the FEZ alphabet only contains 6 glyphs, each of which can have 4 orientations for a total of 24 characters. It is actually a very efficient code in terms of information coding.
http://uk.ign.com/wikis/fez/Fez_Alphabet
It also means a page of FEZ can be read in four different orientations (by repeatedly rotating the whole page through 90 degrees) and thus produce 4 different results (or 8 if you allow reading the actual characters left to right and right to left, 16 if you allow top to bottom and bottom to top).
I think your on to something here. Remember the comment with the waterfall "the exhumation has been reversed". Obviously decoding the fez symbols in the mirror or after rotating would create entirely different characters. I like that idea.
is it possible that like the berenstain bears that the the waterfall image from the past never really existed except in are alternate universe that we seem to have a vague memory of?
}:~) alternatively, what you perceive as reality may be the illusion, and the vague memory may be the last vestiges of true reality. ....
/me brain explodes.
What is the significance of the tiny character in the top left corner, of each of the colour images? Are we meant to use that character for anything else? Do the three characters together form a word, or a Vignenere key?
The marker appears to be FEZ code for 1 (red) ,2 (green) and 3 (blue). I've tried Vigenère on the FEZ fields in various attempts, but without results. Also, the ambivalence of UV and KQ in FEZ kinda break the usual shifting order of a typical Vigenère since the FEZ alphabet doesn't really have a defined order.
