In the last log I did wrote that I did used the wrong footprint for the LEDs. Well it is more the wrong LED for that footprint. The footprint was not a wrong invalid size, I did only used one for a little bit bigger LED. So I do not need to order/design new boards. Ordering new LEDs is cheaper and probably also faster. So both erros are solved by ordering fitting parts.
Awh too bad I was looking forward to seeing you use those small LEDs. What LEDs are you going to use now?
Well I will use LEDs like these:
http://www.aliexpress.com/item/SMD-0603-RGB-LED-diode-1608-RGB-flashing-automatically-led-A-total-of-anode-Free-shipping/32392590219.html?ws_ab_test=searchweb201556_9
There will be a other project where I will use the small LEDs. But this is still in a early phase. The good side about the bigger LEDs this the much lower price.
