I did decide to use just 128 RGB LEDs in a 8*16 Matrix. This reduces the the circuit to drive them. I think I will use one 16Bit shift register (MBI5026 or compatible) for each color and multiplex over the lines. The current for each color can than bes set independent.
I will update details and description of this project to this revison. I think this will be near the final one. At least I am not planing to change the number of LEDs.
Pretty :-)
