LED footprint fail is not so bad
A project log for 384:LED
Mini (1.44'' x 0.94'' or 24mm x 37mm) 8X16 RGB LED Array. 128 RGB LEDs with three LED chip each gives 384.
alexAlex • 03/18/2016 at 20:08•2 Comments
In the last log I did wrote that I did used the wrong footprint for the LEDs. Well it is more the wrong LED for that footprint. The footprint was not a wrong invalid size, I did only used one for a little bit bigger LED. So I do not need to order/design new boards. Ordering new LEDs is cheaper and probably also faster. So both erros are solved by ordering fitting parts.
Stijn wrote 03/25/2016 at 18:58 • point
Awh too bad I was looking forward to seeing you use those small LEDs. What LEDs are you going to use now?
Alex wrote 03/25/2016 at 20:33 • point
Well I will use LEDs like these:
http://www.aliexpress.com/item/SMD-0603-RGB-LED-diode-1608-RGB-flashing-automatically-led-A-total-of-anode-Free-shipping/32392590219.html?ws_ab_test=searchweb201556_9
There will be a other project where I will use the small LEDs. But this is still in a early phase. The good side about the bigger LEDs this the much lower price.
