Soldering and first testing
A project log for 384:LED
Mini (1.44'' x 0.94'' or 24mm x 37mm) 8X16 RGB LED Array. 128 RGB LEDs with three LED chip each gives 384.
alexAlex 05/05/2016 at 19:393 Comments
The first PCB is soldered now. Every thing does fit.
During soldering and the later Testing I found some mistakes in the Schematic:
For testing I wrote some firmware to sweep through all LEDs. The result can be seen in this little video:Next I will write some more advanced firmware.
Rich text editor
davedarko wrote 05/06/2016 at 07:45 point
Seems like you were more productive than I was yesterday. I did the usual "getting stupidly drunk" thing and finished the day with watching Star Trek Voyager :) happy post-man's-day :D
deʃhipu wrote 05/06/2016 at 08:52 point
Hey, that's totally concept work for the hoodie, no?
davedarko wrote 05/06/2016 at 09:14 point
well I was walking the streets with some friends and a beer case - no time for hacking, had to make 10km and finish the beer case in 2 1/2 hours. But yes, watching Star Trek is totally valid for counting as research :D especially Voyager, cause I need to get the neutrino fluctuations and the dampening fields for the dilithium matrices right, or otherwise the matter-anti-matter combustion chamber will deflate because of de-alignment of the dilithium crystals.
