Arduino base Washing machine controller. Buttons and power supply from original board is used. Buttons are mapped as following:
1. Off Button - Turns off motors
2. Wash button - This button turn on main wash motor on and off in 30 sec to emulate resiprocating motion.
3. Drain Button - This button activates Drain motor
4. Dryer Button - This button turns on Drain motor(which also activates mechanical clutch to engage dryer to main motor) and then wait for 20 Seconds before starting main motor. This button only functions when main lid of machine is on closed position.
Please find details on GITHUB link
To control a washing machine using an Arduino, the original board's buttons and power supply are utilized with the following mappings:
Off Button: Turns off all motors.
Wash Button: Activates the main wash motor in 30-second intervals to simulate reciprocating motion.
Drain Button: Engages the drain motor.
Dryer Button: Activates the drain motor and mechanical clutch, then waits 20 seconds before starting the main motor. This function only works when the main lid is closed.
For expert washing machine repair services, visit Al Karama Technical Services.
