Each module contains an nRF51822 microcontroller that reads orientation data from a BNO055 IMU and transmits it over BLE.
In addition, an optional low-profile joystick can be mounted to add extra degrees of freedom to the system or to use for precision movements.
The whole is powered by a 1400mAh Li-Ion battery and includes a USB integrated charger and a State-Of-Charge chip to keep track of the remaining percentage.
Modules can be put to work together in a mesh, or be used individually as a remote control with two smooth movement interfaces and jerk recognition to execute specifc actions.
Alvaro Ferrán Cifuentes
AirCruiser
Shrinath Nimare
Thomas Flayols
Have you seen these little nRF5x modules you can get? I've played with them, with a similar application in mind. The 2nd link is a nRF52832, which is meant to support mesh AFAIK!
https://www.aliexpress.com/item/nRF51-M0-Ultra-small-Bluetooth-BLE-Module-4-0-Module-LIS3DH-Support-10-GPIOs/32697055436.html
https://www.aliexpress.com/item/New-product-Bluetooth-4-BLE-NRF52832-module-BMX055-9DOF-sensor-GT832D-01/32908267663.html?spm=a2g0s.8937460.0.0.1d9e2e0eYG9RDx
